hi, I've got a fat sac that I'm going to instal in the ski locker, where is the best place to gain access to the vent hose on the belly tank on a 210? Do I lift the floor or access the hose by other means? Thanks!
I installed a piggyback under the bow seats and gained access to the belly tank hoses thru the ski locker and under the starboard bow seat. I had to remove a carpeted piece that divides the front port seat from the helm area. I'm sure someone here can provide better direction if you need more, but definitely no need to pull the floor. works great
To get to the vent port hose you want to piggy back to the sac you need to remove the bow backrest in front of the driver windshield. You do this by pulling the bottom of the back rest out( only plastic push tabs holding it in place along the bottom). After you release the push tabs( called Xmas trees ) you slide the backrest up. This give you access to the side port the vent hose is attached too. You can then access the hoses you need through the ski locker and that port. Simple as that
