2013 Nautique 210 - Prop Upgrade, then Ballast Upgrade
  • weally
    • Jan 2014
    • 10
    • Australia
    • 2013 Super Air Nautique 210 Team
    Hey Guys,
    I have a 2013 Nautique 210, A couple of pics are attached, cause everyone loves pictures. These pictures were taken from my drone, at our Nautique Owners Reunion, for New South Wales, in Australia. It was a ripper weekend.
    Anyway, I'm looking at doing a few upgrades to the boat, throughout winter for us, down her in Aus. It is still warm enough at the moment to use the boat, so more like July and August for us, unfortunately the boat will be parked in the shed.
    So as the title says, I'm looking at upgrade the Prop on the Boat, and then looking at changing the rear bags in the back as well. So what does everyone recommended? and what setup are you guys currently running?
    I currently have the ACME 1579 Prop, and running standard Ballast, plus the factory fly high kit, which I believe consists of the following:
    Standard Ballast:
    Belly Tank = 200 kg or 440 lbs
    Rear Tanks = 100 kgs each or 220 lbs, Total 200 kgs or 440 lbs
    Fly High Ballast: Piggybacked
    Front Nose Bag = 300 kgs or 660 lbs
    Rear Bags = 180 kgs or 400 lbs, total 360 kgs or 800 lbs
    These are approximate, so correct me if I'm wrong
    So my questions are:
    PROP UPGRADE:
    I'm looking at upgrading the current prop, ACME 1579, to the ACME 1235 or the equivalent OJ Prop, depending on price/availability etc. and yes I know that this prop could cause prop burn, or is there a better prop to run? but it also means I can upgrade the rear ballast, which is the next question. I want to be able to run more rear weight in the boat, and get it on the plane easier.
    BALLAST UPGRADE (REAR):
    Upon upgrading the prop, I would then look at upgrading the Ballast setup, mainly the rear, which will include, removing the current Bags and also the Hard Tanks, and replacing them with either the Fly High 1100lb (500kg) bags or the Sumo Sacs 1000lb (450kg) which will bring my total ballast from 2400lbs (1100kgs) to either 3300lbs (1500kgs) or 3000lbs (1400kg) depending on rear bags. So it will be more weight in the rear, to help lip the wake up even more, because I like a really lippy wake.
    So guys, let me know what you all think, and any feedback, responses will be appreciated, this will be a winter project for me here in AUS.
    Cheers
    Jake, from AUS
    Click image for larger version  Name:	DJI_0104.JPG Views:	1 Size:	51.3 KB ID:	515786
    Click image for larger version  Name:	DJI_0129.JPG Views:	1 Size:	39.3 KB ID:	515787
    ANd yep, that is a 1953 Correct Craft Aqua Skier, that gets used here in AUS, it is a weapon!
  • cedarcreek216
    • Oct 2009
    • 1009
    • Dallas, TX
    • 2018 210 2013 210 2009 216V
    I have the same boat and run the 1579 with stock ballast and 750's in each rear and a 370 pound fly high tube sac in the ski locker. With a full boat and all ballast full it does struggle to get to wakeboarding speed, but zero problem for surfing. I hear people pulling rear tanks for 1100's and I guess you gain storage by doing this, but my setup is only 100 pounds less in each locker and significantly easier to install.
    • swatguy
      • 1631
      • Midwest/ Northern IL
      • 2008 SANTE 210
      Acme 1617 as close as you can get to the 1235 without going 1235 . Much better than the 1579
      go with removing tanks and adding 1100's
      youll never be able to wakeboard with the 1100's full unless you add 900 plus to the nose. It you can run them full to surf if you don't have NSS and need to list.
      Puling the tanks is as easy as installing the piggy back system. I did a step by step in how to do it if you search my name. And you gain sonmuch more storage if you have to trailer your boat.
      • jbwake
        • May 2004
        • 61
        • Brisbane, Australia
        • 2012 210 Team
        We have run a 1235 on our 210 for a couple of years and no prop burn (although I do know that some 210's get it with a 1235)
        I understand a few boats that have got prop burn have had a small amount of glass ground out in the burnt area and a stainless or alloy block stuck in. Ask Ben from NC in Gold Coast about it.
        In my opinion the potential downside of the 1235 is only fairly minor and can be fixed.
        I have no experience in the performance comparison between 1235 and 1617. Somebody on here may have used both?
        2012 210TE + ZR6 + NSS + Clarion Sponsorship = Good times
        Previous boats ->2001 SAN. 2003, 04, 05, 06 210TE, 07 220TE, 08, 09, 10, 11 210TE
        • nyryan2001
          • Mar 2013
          • 1993
          • Lake Anna
          Jake-- the best wake prop for your boat (heavy loads 0-23mph) is the ACME 2315.
          this is well documented.
          2019 G23 450
          2014 G23 550
          2013 G23 450
          2011 Malibu Wakesetter 247
          2007 Yamaha AR210
          • Phil8uga
            • Oct 2016
            • 383
            • Georgia
            Just curious, but what is prop burn?
            • ScooterMcgavin
              • 1478
              • 2014 SAN 210 TE
              Prop burn is when the prop is too close to the hull and will burn or wear away the gel-coat. Generally caused by to large of a prop that wasn't intended for the boat.
              1989 Sport Nautique
              • swatguy
                • 1631
                • 2008 SANTE 210
                ryan
                the 2315 is a 15inch diameter prop. It will not fit on a 210. The 1235 is a 14.5 diameter at that barely clears. No way a 15inch diameter makes it
                • chopp
                  • Nov 2014
                  • 68
                  hey jake, i have the exact same boat. i'm in nsw. i went through all the info and decided on the 1617 prop and removing the hard tanks and putting 750 bags in the back. nautique central did say that it was mainly the older boats that got prop burn from the 1235 but i didn't want to take the chance for minimal gain if any from the 1617. removing the tanks mean i can fit 2 boards in each locker when there emtpy, and when there full still fit vests ropes ect on top of the bags. I am thinking now the 1100 would of been good instead of the 750, but i have just added a couple of lead weights for now. if you need any more info i'm happy to help.
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    Originally posted by swatguy View Post
                    ryan
                    gotcha. Then he needs a 14.5 x12.5-13 ish.
                    get as close to the 2315 specs as possible. 1235 is a mile away.
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2007 Yamaha AR210
