Originally posted by funkster
View Post
Originally posted by Blamey
How quickly do your pumps fill?
Originally posted by rcsmith727
Thanks for sharing the setup. Are you guys worried about weight limits? My '95 NSS has a 1,250 lb max weight posted on it, so I wasn't sure how much you can push the limits. I've got 750x2 bags in the rear and need some weight in the front.
You definitely need weight in the belly and bow. For wakeboarding, you can get away with just the belly, but for surfing you need that bow weight to elongate the wave.
Not worried at all. From what I've read, those limits are for legal coast guard approval. I've been in a 210 with 1k on each side of the engine a 580 in the belly and a 550 in the bow, the boat wasn't even close to the rub rail.
Sent from my SM-G930V using PLT Nautique mobile app
I'm struggling to ride ropless.
I'm running 750s in the rear, I have a custom 1000# in the ski locker and a 400# bag in the bow.
I am filling the 750s to about 80% because the rear locker isn't clear in my boat. and the the center bag to about 60% and the front full.
I also have a home made suck gate.
At first I thought it was because the board was to small. I bought a 5' liquid force rocket and I weight about 230 but today I had a friend try ride and he couldn't go ropless either.
So I don't know if it's me, the ballast, the board or the suck gate. How do I figure this out?
How deep is the water where you are riding. I have my 06 dialed in for even a beginner to ride without the rope their first time but if I take it into water less than 15-20ft the push dies noticeably. Also, I believe its the starboard side that should surf easier on that boat than the port, but I don't have much experience with the RH prop rotation.
In my 06 I usually have the following setup:
30-40ft water depth
Rear 750s filled 2/3 to 3/4 full
330# belly tank full
500# integrated bow bag filled until cushions start to push up
Suck gate just completely submerged at the front edge of the rear "slant" of the hull
3-4 people in the main cabin of the boat is usually best.
9.5 MPH for beginners and then 10-10.3 MPH once people can easily find the pocket.
That's been enough for 360s and pop shuvits. Of note we only ride with shorter skim style boards, never had much luck with the larger surf style boards. Still can be very touchy, but the water depth is always the biggest factor in wave quality.Last edited by rlwagens; 07-09-2017, 10:02 PM.
I also appear to be taking on water in the back. Is this common? I think it's coming from the swim platform but didn't get a chance to fully investigate.
Also does anybody else have issues with keeping the ski locker dry. I always seem to get water in there and it never fully drains. With the sack in there it is difficult to keep dry.
Originally posted by rlwagens View PostHow deep is the water where you are riding. I have my 06 dialed in for even a beginner to ride without the rope their first time but if I take it into water less than 15-20ft the push dies noticeably. Also, I believe its the starboard side that should surf easier on that boat than the port, but I don't have much experience with the RH prop rotation.
30-40ft water depth
Only the driver in the boat yesterday. but we did have the extra ballast.
Maybe my suck gate is too short, What size should the plate be? I am currently using a 7.25” x 10.5” cutting board as the plate.
Sounds okay, pretty similar size to nr2041's design that a lot of people have been using:
https://www.planetnautique.com/vb5/f...364#post488364
Theres other shapes and designs in that thread but I've had good luck with an exact copy of that one. Where are you attaching the plate?
Originally posted by funkster View Post
I'm completely full in about 3 mins. Be careful with the center and bow sacs, they will be full before the rears. This is only really a problem with the center 580 bag, it will pop the latch from the locker lid before it burps out the overfill drain. I learned that quickly..ha ha
Originally posted by Blamey View PostI also appear to be taking on water in the back. Is this common? I think it's coming from the swim platform but didn't get a chance to fully investigate.
As to the locker ... we have a steep ramp and I pull the plug on the ramp to get that water all the way back and out. If I don't, I too will have water in the locker. I have a mat in the ski locker under the sac, it seems to help air circulate under it to dry.
Originally posted by rlwagensSounds okay, pretty similar size to nr2041's design that a lot of people have been using:
