Lift is a Shoremaster cantilever. Boat is a 92.
Having never setup a lift for a inboard I went with a friends suggestion of narrow bunks that keep me or the wife from over shooting and going to far.
I know the bunks are sitting higher than needed from the crossbars, they are as low as possible but I plan to add more holes to lower the bunks. Currently it seems shakey while cranked up and moving around in the boat.
Is this a result of to high off the crossbars or too narrow with the bunks?
It's easy enough to tie the boat off and remove the bunks so if they should move that's no big deal. I do plan on pulling the bunks off and drill more holes as well as cut off some excess on the bottom.
