2017 g23 550 help
  • natepribyl
    • Apr 2012
    • 27
    • Minnesota
    • 2017 G23 550
    2017 g23 550 help
    Need help boat keeps telling me exhaust temp overheat. Boat is running fine though with engine temp at 170 to 175 and strainer is clear. Happening at both surf speeds and wakeboard speeds so basically boat is a glorified pontoon. Been to the dealer twice and they are trying to tell me it's a sand problem. Big problem is we are deep water only boat. Anything helps thanks.
  • lucky7t
    • Mar 2011
    • 1306
    • Oklahoma
    • 2015 SANTE
    Check the water strainer . Not real familiar with your boat . Don't even know if it has one but mine had cracks right in top . Also pcm has a reflash on some engines that changes the threshold for the manifold temps . Not sure it applies to you but my 15 model 210 had similar issue and has been resolved
    Current Correct Craft Boat
    Correct Craft Boats Owned
    • natepribyl
      • Apr 2012
      • 27
      • Minnesota
      • 2017 G23 550
      For quick reference I have checked all filters and coolant. The error code that keeps coming up is st 1415 exhaust manifold temperature emwt 1. Higher than expected stage 1 and stage 2. Spn number is 441 and 442 source says fuel sender
      • lucky7t
        • Mar 2011
        • 1306
        • Oklahoma
        • 2015 SANTE
        I hate to say but sounds like it needs to go to dealer
        • aussie_naut
          • Apr 2012
          • 3
          • Australia
          • SAN210
          my guess,
          O2 Sensor needs replacing, takes about 2 min, super easy fix.
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            Check impellor is good and the entrance screen to the tranny cooler.
            98% rules out a blockage.
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2011 Malibu Wakesetter 247
            2007 Yamaha AR210
            • wakemaker
              • Aug 2010
              • 237
              thats why u have a warranty if the dear is not taking care of this calll nautique get them involved
              • natepribyl
                • Apr 2012
                • 27
                • Minnesota
                • 2017 G23 550
                Where is the entrance screen to tranny cooler?
                is there a good why to get at the impeller?
                • LakePowellMan
                  • Sep 2015
                  • 58
                  • Utah
                  • 2016 G23, former Mastercraft owner
                  Have your dealer check your senors. I was getting a similar error message on my 16 G23 and the dealer just re-positioned the sensor. He snipped a couple of ties and re-routed a bit to move the senor away from the heat source. Once this was done I never got the error message again. Took all of 5 minutes at the dealer. Good luck.
                  • lucky7t
                    • Mar 2011
                    • 1306
                    • Oklahoma
                    • 2015 SANTE
                    The sensor is screwed into the manifold . Can you post a pic of what he did ?
