Clear depth to bottom of rudder 2016-2017 G23
  • GMLIII
    • May 2013
    • 2797
    Does anyone know the clear depth to the bottom of rudder for either a 16-17 G23; both with no ballast filled and stock ballast filled 100%?. I'm looking for both measurements .
    i was going to take my boat to a coastal area on a trip with some shallow waters.
  • Wake.BC
    • Jan 2016
    • 423
    • BC, Canada
    You also have to take waves and sucking in sand into consideration.
    Personally I'd want more than enough room just to be safe.
    • nyryan2001
      • Mar 2013
      • 1993
      • Lake Anna
      1.9ft as read on the Linc is with the rudder/prop 0-2" from a firm flat sand bottom. 1.9ft is from the bottom hull. So roughly mid/upper thigh deep for a 6ft man.
      3ft is the minimum I'm comfortable allowing the prop to spin in unless I know the bottom very very well.
      and even 3ft in unfamiliar waters... it's in gear only for a second at a time. In and out of gear.
      3ft on the link is nipple deep on a 6ft man. 1.5-2ft clearance.
      with 2850lbs full OEM ballast? Add another 9-12" of draft.
      if you're really concerned.... go full belly ballast only and put your passengers in the bow. This lifts the prop and you can sneak thru even less than 1.9ft.
      warning-- don't go less than 3ft unless you know the bottom well. Even in 3ft, quickly in and out of gear, very very slow. If you see ~2ft, stop, get out and push!
      2019 G23 450
      2014 G23 550
      2013 G23 450
      2011 Malibu Wakesetter 247
      2007 Yamaha AR210
      • GMLIII
        • May 2013
        • 2797
        This was very helpful. Has anyone on the forum driven a G23 across or within Mobile Bay in Al?
