Ours is a 15
Man I don't mind the lead but was hoping to get by without filling up any bags. I have 400# of lead and looking for a couple more hundred. Maybe it will work
Keep in mind the length of the wave is directly proportional to the speed. At 10.8 one will get a very steep short wave. At 11.5 it will be less steep but longer. Add 200 to 300lbs in the bow and it will make the wave longer and less steep. So we shouldn't try to compare waves without stating the speed. As one progresses from just wanting push to riding air 180s, 360s and shuvs it is critical to flatten the wake. On a new G23 this is done at NCRS 2-3, NSS at 0 or 1 and 200lbs in the bow. I also have 200 on port side rear, 150 on starboard side rear and 150 under both side middle seats. But I usually only have two others in the boat. With more people, someone has to ride in the bow to keep the wave manageable for revert riding.
Sent from my SM-G935V using PLT Nautique mobile app
Originally posted by SailfunWhat do you tow this boat with? Did you upgrade the trailer for the extra 700lbs of lead?
Originally posted by Jakeb View Post
Is this a serious question? I don't thing an G comes with a trailer barely rated for it. Mine is good up to about 8k
your trailer is probably rated for 8k+. That is true....... but let's think about that for a minute.......
G23 Dry- 5800
Trailer- 1600
Fuel- 409 (65 gallons at 6.3 lbs/gal)
Gear- 300ish (engine oil, coolant, life jackets, FE, anchor, ropes, cooler, etc etc.)
total- 8109 without any lead at all.
Food for thought...... if you happen to be ordering a new G, or a trailer for a G, and you plan to use 500+lbs of lead.....I would recommend asking for 5200lb axles on the trailer. (Or a tridem with 3500lb axles.)
Originally posted by Neverenough View Post
Well it starts with a wife.....lol she really liked our 230 and the different wave. G is just different that's all. Not sure I'd call it better just different.
The G wakeboards better. It should. It was built from the ground up to be a wakeboard boat.
The 230 handles better. It isn't even close. He nicknamed his G23 "The Walrus" because of how bad it handles.
The 230 surfs longer, the G23 surfs steeper. Neither is better, just different. Personally, I enjoy the change. It makes me a more versatile surfer.
-Charles
G23 Dry- 5800
Trailer- 1600
What you calculated here is the TOTAL weight which you do need to know when you're figuring out whether or not your tow vehicle can pull it.
-Charles
Wayward, when you're calculating the total weight the trailer can carry, you do not count the weight of the trailer itself. That's not how it works. So above, you have to take that 1600 pounds out.
-Charles
Where do you see a payload rating on your trailer?? The only ratings I ever saw, were the gross axle weight rating (GAWR), and the gross vehicle weight rating (GVWR). Both of which need to have consideration of the unladen weight......
-Charles
I think you need to consult with the trailer manufacturer here. They can tell you for sure how to calculate the load.
-Charles
i assumed by your statement, that the trailer company had a payload rating on it somewhere, and you didn't need to know the empty weight of the trailer to know the payload capabilities. I have never seen this on any trailer before. The only thing they list are axle ratings and GVWR...... which, if you are using those, you definitely need to know the unladen weight of trailer, to figure out the rated payload.
Think again....... it is barely rated for it.
G23 Dry- 5800
Trailer- 1600
On the boatmate website they are offering an "XL" or extra load tandem axle trailer for the G23, maybe the only difference between the XL and the regular is the XL comes with the 5200 lb axles...I cannot seem to find on there website the axle ratingLast edited by ironpeddler; 08-11-2017, 02:15 PM.
^ The standard axle rating on the boatmate G23 trailer is 4200lbs per axle. Standard GVWR is 8400lbs. Subtract the 1600lb unladen weight, and you have 6800 available..... which is about exactly what a G23 weighs with just fuel and gear. Extra lead is not a good idea with standard trailer.
Originally posted by Wayward^ The standard axle rating on the boatmate G23 trailer is 4200lbs per axle. Standard GVWR is 8400lbs. Subtract the 1600lb unladen weight, and you have 6800 available..... which is about exactly what a G23 weighs with just fuel and gear. Extra lead is not a good idea with standard trailer.
