Weighting 220 using suction surf device???
  • brycejay
    • Apr 2009
    • 54
    Just getting ready to order a few sacs to throw in my 06 220 with the ZR6 engine. I mostly wakeboard but I'm taking the boat to lake Powell next week and most people will want to surf. I'm going to borrow my buddies mission delta surf device to use while I'm there. Right now all I have is the 3 stock tanks. I'm just going to order some sumo sacs to throw in the boat and manually fill them. Which sacs should I order and where will be the best place to put the weight if I'm not listing the boat? I need to order the sacs by Monday to get them here in time so any help is appreciated!
  • a0128
    • Jan 2014
    • 423
    • Lake Oswego, OR US
    • 1999 Pro Air Nautique
    Take a look at this video. May be of some help.
    https://www.youtube.com/watch?v=Tl1kzbgmW74&app=desktop
    • Paxdad
      • Mar 2013
      • 775
      • Cumming, GA
      • 2008 210 SANTE
      Honestly the three stock tanks and the passengers with the suck gate should make a surfable wave without added expense of more ballast.
      2008 210 SANTE
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        Wakemakers.com has bags in stock...they made custom sacs for my boat, good customer service too
        • brycejay
          • Apr 2009
          • 54
          Paxdad, I think I might just try it with the stock ballast and passengers. We will most likely be loaded with people all the time so that just might work.
          • Paxdad
            • Mar 2013
            • 775
            • Cumming, GA
            • 2008 210 SANTE
            Reply back with outcome. You should be fine.
            2008 210 SANTE
            • wakeskier
              • Oct 2007
              • 77
              • Massachusetts
              • 2008 Super Air Nautique 210
              For reference if you decide to add bags, this is the surf setup I use for my '07 220 with a suck gate:
              Stock Ballast full
              ~400 lbs under each rear seat
              750 lbs bags piggybacked in the rear lockers (surf side completely full, other side 3/4 full)
              Arrow sac piggybacked in the center locker
              11.2 mph
              This is with only 2-3 people in the boat and the wave in money!
              • vanhanbr
                • Mar 2014
                • 223
                • Wisconsin
                • 2008 SAN 210
                Buy (2) 750s for the rear locker and either an arrow sac or a bow filler sac and you will be in great shape. You will need a pump as well.
                Once you get it dialed in, you may want custom sacs. These are common sacs and easy to offload if need be.
                2008 SAN 210
                1997 Sport Nautique
                • beamons
                  • Jun 2017
                  • 376
                  • Utah
                  Don't forget the shaper. This has made all the difference with my '04 SV211. Have fun in Powell, we are there at the end of the month.
                  • brycejay
                    • Apr 2009
                    • 54
                    Thanks for the replies. I think I will go ahead and order a couple sacs just to be safe. I will let you know how it goes!
