Just getting ready to order a few sacs to throw in my 06 220 with the ZR6 engine. I mostly wakeboard but I'm taking the boat to lake Powell next week and most people will want to surf. I'm going to borrow my buddies mission delta surf device to use while I'm there. Right now all I have is the 3 stock tanks. I'm just going to order some sumo sacs to throw in the boat and manually fill them. Which sacs should I order and where will be the best place to put the weight if I'm not listing the boat? I need to order the sacs by Monday to get them here in time so any help is appreciated!
Take a look at this video. May be of some help.
https://www.youtube.com/watch?v=Tl1kzbgmW74&app=desktop
Honestly the three stock tanks and the passengers with the suck gate should make a surfable wave without added expense of more ballast.
Sent from my iPhone using PLT Nautique2008 210 SANTE
2008 210 SANTE
For reference if you decide to add bags, this is the surf setup I use for my '07 220 with a suck gate:
Stock Ballast full
~400 lbs under each rear seat
750 lbs bags piggybacked in the rear lockers (surf side completely full, other side 3/4 full)
Arrow sac piggybacked in the center locker
11.2 mph
This is with only 2-3 people in the boat and the wave in money!
Buy (2) 750s for the rear locker and either an arrow sac or a bow filler sac and you will be in great shape. You will need a pump as well.
Once you get it dialed in, you may want custom sacs. These are common sacs and easy to offload if need be.Last edited by vanhanbr; 09-11-2017, 09:24 AM.2008 SAN 210
1997 Sport Nautique
