Let me clarify some things,:
According to the 2014 owners manual the maximum cruise speed for the 343/409/450 is 4000 rpm. That is different from cruise speed, which is typically the term used to describe the most fuel efficient speed to travel to get from point a to b.
I used 14 pitch as an example because more than one poster mentioned propping down to improve pull times. I agree that it takes real world testing to find actual speed, but you can not go any faster than the calculated theoretical speed (0% slip). Slower, yes, I used 10% slip because that is pretty much best case real world and what I experienced on my own boats as well, 0% will never happen.
The 343 might be ok for surfing, but what if I just wanted to go for a boat ride? or drive to a surf spot? 19 pitch prop, max cruise speed 32mph or you can still cruise at 24 mph and 3000 rpms. I think it is safe to say the 343 will not spin a 19" prop.
Tallredrider 30 mph with 17 pitch prop 2.00 tranny 4000 rpm is 7% slip, 29mph is 10% slip What you said sounds about right.
Straight from owner's manual :
Best all-around performance and maximum engine life is achieved when the engine is propped to run near the top of (but within) the recommended full throttle RPM range with a normal load.
The potential buyer should load the boat up at whatever elevation, crew, ballast, etc. is "normal" and make sure the 343 can still spin to 5000 RPM WOT (per manual.) Then we would know if engine damage could occur.
