1997 Sport Nautique - Lift Size
  • Liamfm
    • Aug 2017
    • 74
    • Vermont
    Hi all, Debating a lift and slip for next year and wondering what size lift people use. Looks like I'd be right near the upper end of a 3K lift. Are most people with a sport nautique (or maybe even a SN) up into a 3500 or 4k lift?
  • xlair
    • 694
    • Wisconsin
    4000 lb to be safe
    2001 Pro Air Nautique
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      That boat weights 2700 pounds. With a full tank of gas it's 2882 pounds. You're well within the limits of a 3000 pound lift. Check with your dealer and see what they offer. Mine only does 3000, 6000, and 10K lifts.
      -Charles
      • Evening Shade
        • Apr 2015
        • 1295
        You should be fine with a 3000# lift, but I would recommend going with a 6000# lift. The cost difference shouldn't be all that significant between a 3000# and a 6000# lift. Down the road if you buy a heavier boat it will cost you about $1 per pound to upgrade from a 3000# to a 6000# lift. Charles and I both know this well because we both upgraded to 6000# lifts recently.
        Buy once, cry once.
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Buy once, cry once.
          Yep. That said, my house was a spec so the dock and lift was already in and the builder installed a 3K lift. It was fine for 17 years with my 99 Air Nautique. When the 230 came along however...
          -Charles
          • wawasee
            • Sep 2011
            • 111
            • Indianapolis
            • 1995 Sport Nautique Previous: 2006 SV211 1991 Spor
            We have a 3600lbs Shore Station. Works great
            • scottb7
              • Aug 2011
              • 2198
              • Carson City, Nevada
              Yeah, you gotta plan like 2 or 3 boats into the future...or you gonna hate yourself every time you trade lifts...Both those guys above eventually got to the #6000....
              Just get a #6000 now...and later you will feel like the smartest guy ever...
              I received with the house a shoremaster 2596 (#2500), then got a 36108 (#3600), and now have 50120 (#5000). I never thought I would trade the 210...but yeah whatever's....
              • Quinner
                • 2246
                • Correct Crafts
                If you are considering a vertical lift like a Shorestation the 4k lift will be easier to crank up then the 3k lift. Unless you are certain you are going to upgrade stick with a 4k lift. Even if you do find yourself needing a larger one, used 4k lifts are easy to sell and hold their value pretty well. (2) best brands out there for Vertical's are Shorestation and Floe IMO.
                One other consideration with a SS brand, the 5k+ lifts are substantially heavier/larger then the 4k's which makes them much harder to move in/out each season.
                • vanhanbr
                  • Mar 2014
                  • 223
                  • Wisconsin
                  • 2008 SAN 210
                  I have a floe v-4600. Was a pretty big difference in cost between that and a vsd-6500, but yeah, I should have bought the bigger one.
                  2008 SAN 210
                  1997 Sport Nautique
                  • Tryathlete
                    • Feb 2015
                    • 217
                    • Lake Villa, IL
                    • 1996 Nautique Super Sport
                    I bought a 3600 shore station and as Quinner says it is a total pia to crank up. I upgraded the winch to 4000 which has a spur gear for reduction and it flies up with my 1996 Super Sport—which is probably similar in weight to the Sport.
                    • shag
                      • 2217
                      The cost difference is not that much to just go ahead with a larger capacity lift... You will not regret it imo.
