Domed Numbers Lettering Overlay Pics
  • GMLIII
    • May 2013
    • 2797
    Originally posted by mlsurfco View Post
    How difficult are these to put on?
    I just ordered the stern Nautique overlay as an experiment to see how difficult they are /or/ are not to install. This is a much easier task to manage plus I can see how well they hold up before I purchase them for both sides of my boat.
    • blueroom
      • Mar 2017
      • 623
      • Northwest
      • G23
      They are actually really easy to install. Some letters are a little more complicated than others, but the technique is the same.
      I peeled the facing off first, then removed the backing. You can start in one corner or along one edge and work your way around. If you don't press them down, you can peel them up, remove and start over or adjust as you go. You just take your time and they turn out great, With mine, the factory letters have a shade or matte part, and the overlays are essentially the same size as that part of the letter. You can use that as a guide and make small adjustments as needed.
      I found that if I took a level photo of each letter with the overlay just tacked on in some spots, it helped me see any lines that weren't straight or if it looked crooked, off center, etc. If good, press hard around the whole thing and commit, or make necessary adjustments. Don't get frustrated, some go on quick and others take a bit, I had an "E" that I probably re-did 10 times.
      I also hit the letters with a little rubbing alcohol first to remove any polish or residual Babes.
      Realistically, I spent about 45 minutes on the first side and abut 30 minutes on the second side. I did the two sides on two different days, as I found my focus getting off towards the end of each set of letters. A short break between probably would have been fine.
      • GMLIII
        • May 2013
        • 2797
        Good detailed info. I'll wait for the post from the PN member, who puts the overlay lettering on by applying them in the upside down body postion. Since I don't own a trailer, I would be applying these overlays while my boat is in my lift as my body is hanging over the gunwales applying the lettering. Maybe someone has a better application method for someone who does not own a trailer? LOL
        • Kmayotte
          • Apr 2010
          • 819
          • Lake Winnipesaukee, NH
          What's your water depth? What about a step ladder in the water?
          • nohlan_4
            • Jan 2016
            • 418
            • Canada
            • 2013 G23 450
            Beach the boat if you have a sandy bottom and do it from the water?
            • GMLIII
              • May 2013
              • 2797
              #21
              Never thought of that , I guess I could beach it and apply the lettering standing in the water. Makes sense.
              • mlsurfco
                • Oct 2015
                • 191
                • Minnesota
                • 2017 G23
                #22
                GMLIII I feel your pain. No trailer here so thinking about doing it while the boat is on the lift but there is lots of $hit in the way!
                • GMLIII
                  • May 2013
                  • 2797
                  #23
                  There is no way I would try to apply these in the lift with my body upside down. I will experiment with the application of the stern logo overlay first and if successful then figure out the application of the side overlays before I order them
                  • blueroom
                    • Mar 2017
                    • 623
                    • Northwest
                    • G23
                    #24
                    Pic of the transom overlay in white - before and after. Same awesome product, and looks really good.
                    • GMLIII
                      • May 2013
                      • 2797
                      #25
                      Glad you posted the transom dome overlay. I just purchased the transom dome overlay in Midnight Blue and have not installed it yet and your visual is helpful.
                      • RDT-G23
                        • Jun 2017
                        • 589
                        • TEXAS
                        • 2020 G23 PARAGON I 2017 G23(sold)
                        #26
                        Amen, and Roll Tide!
                        • jharris
                          • Sep 2010
                          • 243
                          • Michigan
                          • 2022 G23
                          #27
                          Did you install the domed overlay yet on the transom. I want to do the same thing with my Admiral Blue and I was anxious to see how your boat turned out.
                          • GMLIII
                            • May 2013
                            • 2797
                            #28
                            Saw your boat ; beautiful.
                            I have the transom dome overlay but have not installed . My boat is at desrlership inside where I left to get warranty work done late last fall and I just left it there all winter. I’ll probably pick up mid March then I will install the transom dome overlay and Roswell Triton racks . Will post pictures at that time
                            • mnovstel
                              • Jan 2012
                              • 89
                              • Cambridge, ON, Canada
                              • 2013 G23 2002 SANTE (previous)
                              #29
                              Looks great blueroom! I’m thinking about doing this on my boat in the spring.
                              Are these letters “puffy” for lack of a better word to describe it or more flat like traditional vinyl lettering?
                              thanks
                              2002 SANTE
                              • GMLIII
                                • May 2013
                                • 2797
                                #30
                                They are thicker than vinyl lettering for sure but not puffy
