How does someone to go about finding the correct HP ratings for older SN. I am looking at sereral early 90s SN and I am getting told various HP ratings from the owners. Looks like the same 351w in several of them but one owner says 240 HP and another says 290 HP. Any distinct markings or obvious numbers that would help so that the average Joe can tell what they are going to be purchasing?
RE: Early 90s SN Horse Power Ratings
The difference between boats with 240-255HP and 285-310HP 351w's is the heads. The HO motors (ProBoss, some ProSki TBI and GT40) have GT40 heads that add ~45 HP.
The identifying mark on the heads can be seen in this picture. This is a picture of GT40P heads, which are different from GT40 heads. Notice the 4 bars on the side of the head on the GT40P's- the GT40's will have 3 bars in the same location.
1990 Ski Nautique
NWCT
Look at the exhaust also. My '91 sport had a 240hp 351 with a single exhaust out the back of the boat while the pro boss had 2.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
1991 Sport Nautique - sold
As far as I know, every Ski Nautique from 1989 with the 351w has had single outlet exhaust. I believe all the 350 chevys are the same as well. The only true dual exhaust I have seen on a Nautique since '88 was on the few boats with the Python motors.1990 Ski Nautique
NWCT
how hard would it be to convert to a dual exhaust? Is the tiller in the way? can you just eliminate the junction box and run straight out the back? Just wondering if anyone knows. thanks
The rudder hardware is mounted on the opposite side of the single exhaust. I believe there is room to run another pipe, but it wont be symmetrical with the one that is already there.1990 Ski Nautique
NWCT
TRBenj is correct. However, the rudder hardware can be moved out of the way. Basically you need to make a bracket to hold the rudder torque tube clamping block to the mounting bolts for the strut. Should then be adequate space for a 3" exhaust pipe.
Re: RE: Early 90s SN Horse Power Ratings
Originally posted by DavidFTRBenj is correct. However, the rudder hardware can be moved out of the way. Basically you need to make a bracket to hold the rudder torque tube clamping block to the mounting bolts for the strut. Should then be adequate space for a 3" exhaust pipe.
I know all the boats prior to '89 routed the dual exhaust outbound of the main stringers. How do the newer boats with the big block Pythons route their exhaust?1990 Ski Nautique
NWCT
RE: Re: RE: Early 90s SN Horse Power Ratings
That is a good question. I was just hypothesizing on my response. I cannot remember if the tiller arm is high enough for the exhaust to pass under, it would be close and might requre a slightly flattened exhaust tube/pipe to make work.
Yes, I am talking about the clamp block that holds the steering cable to the side of the stringer. The clamp block holds a torque tube (so to speak) that the cable slides in and out of. This "tube" is what is repositioned in the clamp block to center the steering wheel for straight ahead running.
Re: RE: Re: RE: Early 90s SN Horse Power Ratings
I understand now. On my boat, the "torque tube" is mounted just off the centerline of the boat, so there is plenty of room between the cable and stringer. My tiller arm is mounted at the perfect height to prevent running an exhaust hose next to it- though if it were raised or lowered, it may be possible to sneak one by. Still, I think the tiller swings back too far to allow a symmetrical mounting of a dual exhaust. It would be very cool to have a setup that looked like this:1990 Ski Nautique
NWCT
