Best motor for altitude?
  • kylant
    • May 2010
    • 540
    • Lake Tahoe
    looking at a new boat. 2 boats I am considering have the ZR4 and 1 has the H5. the boat I really like has the ZR4. boat will live most of its life at 6500ft. wondering what the best motor for altitude is?
    I know I could do a prop change.
    Suggestions? thanks
  • nohlan_4
    • Jan 2016
    • 418
    • Canada
    • 2013 G23 450
    H5 probably, depends on which boats and the size.
    • kylant
      • May 2010
      • 540
      • Lake Tahoe
      Originally posted by nohlan_4 View Post
      h5 probably, depends on which boats and the size.
      gs22
      also looking at a 230 with the ZR 409
      • nohlan_4
        • Jan 2016
        • 418
        • Canada
        • 2013 G23 450
        Originally posted by kylant View Post
        gs22
        What are your plans for the boat? If it was swapped I would say you probably be fine but if you want to surf with upgraded ballast or wakeboard you might find that motor lacking at that high of altitude.
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          These 2 engines are very similar in torque. I have the ZR409 (similar to ZR4) in my 24ft boat and run almost 5k of ballast with zero issues at 800ft elevation. Obviously a different story at 6500ft. IMO, both engines will be similar and will either be just barely ok at that elevation with the right prop, or you will need the H6 engine. I think you have to test them in situation like this....probably need the H6 with a good deal of ballast.
