What is the final debate on these props. I would like to reduce some engine noice at surf speeds and cruising speeds. Usually only use stock ballast with 400lbs lead.
Tags: None
Originally posted by Whitetail15 View PostWhat is the final debate on these props. I would like to reduce some engine noice at surf speeds and cruising speeds. Usually only use stock ballast with 400lbs lead.
I'm interested in this discussion. I will be buying a second prop soon so I always have a spare.
I have lined my entire engine compartment with dynomat. About 375.00 dollars worth. I did not notice a difference at surf speeds. Just idle.2016 G23
I received the 8087 prop today. I will install it this weekend and report the RPM we achieve while surfing under identical conditions as the stock 17"x17". It will take me a few weeks to record an accurate fuel burn. I also plan to use a sound pressure meter to record engine noise before and after the prop switch.
The good thing about going straight to ACME is that they offer a 30 day trial on the prop. If this one doesn't work out I can swap it out for a different pitch/diameter to achieve the performance I am after.
Sent from my SM-G950U using PLT Nautique mobile app
I’ll help you jump straight to the results:
17x17 will burn more fuel and run higher Rpms than the 17.5x17.5
if your goal was to burn less fuel (lower rpms) and run quieter, you’re not going to do it going that route2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Originally posted by nyryan2001 View PostI’ll help you jump straight to the results:
Originally posted by greggmck View Post
I think you misread my post. I currently have the 17x17 prop. I am changing to the NEW 17.5 x 17.5. The new prop has a HIGHER pitch and GREATER diameter. It will turn lower RPM than the stock prop. When an internal combustion engine produces lower RPM to achieve the same speed it burns less fuel. Yet you say that wont happen?
Ok, gotcha, I thought you were going the other direction.
you’ll see a 2-300rpm reduction difference for the same activity and weight going to the .5” larger and .5” more pitch’d prop. Good luck
2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
Originally posted by nyryan2001 View PostOk, gotcha, I thought you were going the other direction.
you�ll see a 2-300rpm reduction difference for the same activity and weight going to the .5� larger and .5� more pitch�d prop. Good luck
Agree. That is the expectation. I am interested in measuring the relative reduction in engine noise, fuel burn improvement and the affect on the list angle of the boat while surfing. The greater diameter prop should translate increased rotational moment on the hull impacting the surf wave, perhaps increasing the starboard side wave at the expense of the port side. My hope is this is not significant as we primarily surf the regular (port) side. I will use a tilt gauge to measure any increased list of the hull while surfing that the new prop may induce.
I hope that is not the case. Seems like the portside always gets the short end of the stick in regards to surfing when the majority of folks surf on the portside vs starboard.
I am surprised anyone is complaining about noise. Compared to every other boat I have been in, the G is the quietest of them all.
If you get some problems with increased listing, it could be pretty easily offset with a ballast adjustment. With your presets available, you would only have to do it once.
