Yes I meant the key way channel. Here is a picture of my broken shaft. If you zoom in you can see the key way channel is cut longer than the prop hub and is long enough to streach all the way to the rear of the strut. This is the failure point. I don't have a picture but the key way channel on the "updated replacement" shafts is shorter and is completely covered by a prop with a 2.5" hub.
Knowing what I have learned I would not be changing props with any shaft that has the longer key way as any issues with the taper junction between the prop hub and the shaft taper can exacerbate the failure. Part of the repair bulletin is to use dye on the shaft taper and prop hub to check for a good fit of the taper of the shaft to the prop hub.
If you do lots of surfing especially with additional ballast (+500lbs) and/or a large crew I would be asking my dealer to preemptively replace the shaft.
Sent from my SM-G965U using Tapatalk
