Engine Hours on New Boat
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Curious as to what others have seen as the engine hours on new Nautiques. I picked up my new 200 a couple of weeks ago and was surprised to that the Linc system indicated 0.0 engine hours.
    Is this done intentionally to monitor customer hours or does mine just have that little time on the engine? Hoping for the maiden voyage this coming Friday and if the hours are really this low, as in none, I will pay extra close attention to everything.
    TIA.
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    It doesn't have 0 hours on it. The display will show 0 hours until the ignition is turned on. You have to enter the code, hit Start, and then hit Start one more time to bring up the ignition and ECU. Most likely the boat has 3 or 4 hours on it already from factory and dealer testing.
    -Charles
    • Green
      • Feb 2018
      • 87
      • KS
      • 18-G23
      Mine had around 1.1 which is inline with the dealer water testing etc of the boat.
      Previous boat and different brand when new had around 10 hours on it and later I found out the dealer was taking customers out on my boat!
      • ironj32
        • May 2011
        • 601
        • 2018 SAN G23 XR550
        mine usually have between 1.5-4. my 2018 G had 2.2 on it.
        2018 SAN G23 XR550
        2015 SAN G23 XR550
        2014 SAN G23 XR550
        2013 SAN G23 XS550
        2013 SAN G23 ZR450
        2011 SAN 230
        2010 SAN 230
        2000 XStar
        www.mnspringride.com
        • wakejunky
          • 679
          • Ca
          • 2003 SAN
          I thought CC water tested all their boats at the factory. I would expect at least 30 minutes on the clock.
          • j2nh
            • Dec 2003
            • 628
            Yup, you guys were right. 1.0 when the system came up and went online. Thanks, not used to the Linc system, this is going to take some getting used to.
            2018 200 Team H6
            1987 ProStar 190
            • wakerider107
              • 271
              • south
              Nautique puts 30-45min on each boat. The dealer probably adds some time as well.
              2012 SANTE 230
              • Kinloch
                • Jan 2016
                • 46
                • New zealand
                • 2018 gs20
                Mine had 1.4 hours on it straight from the factory.
