NCRS auto High or Low
  • jphdrake
    • May 2014
    • 32
    • Dothan, AL
    • 2017 G23 550
    I have my NCRS in auto mode on Low on my 2017 G23. Can someone explain the difference between the high and low mode as to how it makes the boat perform. I'm specifically interested to figure out if one setting or the other would help to get on plane faster when wakeboarding with full factory ballast and about 10 people of extra weight. I know a prop switch would make a bigger difference but after all the years on a G I realized I really don't know what the difference is between the settings.
  • charlesml3
    • Jan 2008
    • 2455
    • Lake Gaston, NC
    • 2022 G23
    Low: The NCRS plant will move in small increments to help the boat get up on plane quicker and stay on plane through turns. Low is best for lightly loaded boats.
    High: Same as above, but better for heavily loaded boats. The plate moves more aggressively.
    • ironj32
      • May 2011
      • 601
      • 2018 SAN G23 XR550
      I would just always leave it set at high.
      2018 SAN G23 XR550
      2015 SAN G23 XR550
      2014 SAN G23 XR550
      2013 SAN G23 XS550
      2013 SAN G23 ZR450
      2011 SAN 230
      2010 SAN 230
      2000 XStar
      www.mnspringride.com
      • GMLIII
        • May 2013
        • 2798
        Like Ironj32 states I keep mine set on high at all times. Also to note if you have the NCRS set to a specific level during your saved wakeboard and wakesurf settings the auto feature is not functioning while the preset level are in operation.
        Although not mentioned anywhere in your owners manual, you will notice a small icon on the bottom of your LINC screen when the auto NCRS is engaging showing an up arrow or down arrow.
