Has anyone had any good or bad experiences with different makes of check valves on their ballast system?
I have all wakemakers components in my 2001 SAN. I use the reversible johnson pumps. On the front side of the pump, the fill fitting is from the bottom of the hull, but i discharge overboard to keep a tattletale. I use 2 check valves to make it work. My two rear pumps work fine. When I'm filling, my front system keeps getting air slipping by the overboard check valve and the pump loses prime. I replaced it last year and and it has started doing it again.
Looking at the check valves closer, it's just a flap, no real spring or anything. Anyone have any experience with better check valves?
The other thought i had was rerouting the line to have a low spot to force it to hold water and stop air slipping in. pee trap of sorts.
