You said you changed the plug wires, correct? Why not simply change out the new wire in question with the old one and water test to see if that is the problem? Just an FYI, I would always use OEM parts from a nautique shop or online source like Nautique parts. Going to a local car shop is not recommended as marine parts are different from car parts. I don’t know if you’re doing this but it can lead to problems when tuning up your motor. Did you gap your plugs? I believe, they should be at .045.
