hello all, I saw this super sport online and was wondering if I can just get the trim pieces I circled in the pic...thanks
Tags: None
Nautique parts sells these.
https://www.nautiqueparts.com/produc...ps-gray-brown/
Not sure about the rest but you can do a custom order from seadeck. They send you a sheet of mylon, you do a rough trace of you design, they send back a mock up and you check fit and order the part.
Yeah I like those as well and would be interested if you find them. The other thing to do would be call Roswell or SeaDek. They did a SS promo boat a while back. Too much SD for me but they may have those templates in a computer somewhere. Search "Roswell Super Sport" images and you'll see it.
thanks, I contacted them through email and sent them the same pic. we'll see what they say... since this has already been done I would not think I would have to go thru the measuring and template process again.
Give scwake.com a try too. Good people and good customer service. They can do any shape custom you need.
Check out my thread “2001 Super Air Nautique Seadek Templates”
I know yours won’t be identical. But there is a guy who called the place that did mine and got a few things changed to make it right for his year. His turned out great and is more similar to the picture above as far as tower.
perfect!! thanks man! exactly what I was looking for...I'll research further after I go thru your thread!!
Originally posted by brit_hunsicker View PostHere is what Rusty Barras did. He used my templates and made a couple changes with Dek Designs to fit his boat. We are both very satisfied. Several people have copied my templates with no issues.
Sent from my iPhone using Tapatalk2009 Super Air Nautique 210 TE
1989 Sport Nautique
I used Gatorstep. They sent me Mylar, I made the templates, went back and forth a few times with the designer, they sent out paper test pieces, back with the designer for final layout, then pieces cut and back to me. The whole process took right at a month. I was extremely happy with the folks I worked with at Gatorstep
