I just started surfing and cant find the sweet spot. I was told that the wake is better on the 210's on the starboard side but then someone was saying that on the 06 its better port side. it seems better starboard side but that could just be the driver weight. we have just been filling the single side ballest, and leaving the belly emty. what should I do, and what side is better? Also what board should I be using since I am about 6' 255lbs?
RE: need surf help for 06 210 sante
On the 06 you want to be on the port side (that is weird to say for a nauti). Fill the center ballast and the port ballast. The center ballast will help move the wave further from the boat. Then I would add another 350 on top of the back tank and one in the seat. Then have everyone sit on the bag on that seat. If you have a jump seat have the driver sit in that and drive. As for a board. I used to weigh 245 on am 511. I rode a 5'6" surf board then and it was fine. Hope that helps.
jeremy
