Wave Size and Water Depth
  • btouchstone01
    • Aug 2015
    • 56
    • Tallahassee, FL
    My son is studying the effect of water depth on the wave size for wake surfing. I will not bore you with the physics because a picture (or 4) is worth a thousand words:
    2015 Sort Nautique with 750 lbs of balast at 9.5 MPH
    Click image for larger version  Name:	image_44363.jpg Views:	1 Size:	68.3 KB ID:	571076 5_5_ft.jpg Click image for larger version  Name:	image_44364.jpg Views:	1 Size:	59.7 KB ID:	571071 Click image for larger version  Name:	image_44366.jpg Views:	1 Size:	58.8 KB ID:	571074
  • GMLIII
    • May 2013
    • 2820
    Very noticable difference in wave size no doubt
    • doug69
      • Sep 2015
      • 94
      • Canada
      • 2016 230
      You are a brave man to ballast up and drop that rear end in 3 feet of water.
      • ihaveansv211
        • Oct 2005
        • 165
        • New England
        Are you using a wakesurf shaper? That boat looks pretty level.
        www.shredcandlewood.com
        • btouchstone01
          • Aug 2015
          • 56
          • Tallahassee, FL
          No wake shaper... just stock ballast tanks...
          Sent from my SAMSUNG-SM-G930A using PLT Nautique mobile app
          • rlwagens
            • Feb 2008
            • 147
            • Michigan
            • 2006 SANTE 210
            Taking this further, I've found the push on my lake decreases dramatically below 20ft of depth, and everyone can ride for days in 40ft of depth. I'd imagine the point at which the quality levels off at its peak is somewhere between those depths. Best riding I've had was in Cumberland with 100ft+ of depth, but also the boat is filled beyond the max with people so it distorts it a bit.
            • ZIRB3L
              • Jun 2013
              • 77
              • Griffith, IN
              • 2003 SANTE
              Cumberland = 100ft for miles. I need to go back there again. I need deeper lakes by me.....
              • thejean
                • Aug 2017
                • 364
                • Calgary, AB
                Our lake is max 20’ unfortunately. I find less than 13’ the wave sucks. At around 8’ no push. Not much difference between 13’ and 20’. Would love to try >20’.
