Boat garage setup pics
  • GMLIII
    • May 2013
    • 2797
    Wow that is a sweet set up
    • Tom_H
      • Jan 2014
      • 244
      • Minnesota
      Originally posted by Infinity View Post
      I am not experienced in wiring or HVAC, is there an easy way to explain how I would wire it to an external thermostat? If its over my head, I could pass it on too either my HVAC guy or electrician and likely get it done fairly cheap since I provide them with a lot of work since I am a General Contractor by trade.
      I know my pics of the heat/AC are not very detailed....but it just a basic system that looks like a window unit, but is designed to put into an external wall since it had a "sleeve", tho it would likely function just fine as a window unit too. It has a single power wire and the thermostat is built into the unit and the pre-set settings range from 61-80 degrees, so wondering how I could put it on an external thermostat like you suggested since to me, there would be multiple benefits doing that. Beyond that the system has plenty of power to easily cool or heat the entire garage space (partly cause I insulated the entire garage space really well since I wanted it to be as efficient as possible) and the $1k I spent to over-insulate the walls/roof, will likely be re-couped in 2yrs time since the unit will not run nearly as much if it was not insulated at all. Weakest point is the 12x12 door, even tho the garage door is insulated, I am sure the R-value is well below my walls/ceilings.
      Thank you for the suggestion!
      Somewhat depends on the heater/power source. If' it's just a 120 plug-in unit that returns to previous operation upon power-up, an in-line one like this would be a simple adder if your within the amperage rating (and then remove it in the summer when you switch to cooling) as it just interrupts power to the unit. https://www.globalindustrial.com/p/h...CABEgLa4_D_BwE
      Alternatively, most of those wall units have terminals for wiring in any generic remote thermostat, and usually just have to flip a dip-switch to enable the remote control and disable the on-board control. You'd have to check the manual for your particular model.
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        Great info, and thanks for the link. I am gonna look info this deeper for sure!
        Sent from my SM-G930V using Tapatalk
        • Infinity
          • Sep 2017
          • 730
          That setup from Wayward is without a doubt, bad to the bone!! Love it
          • brit_hunsicker
            • Oct 2014
            • 482
            • Overbrook, KS
            • 2001 Super Air Nautique
            Nothing special, but heated and that’s nice for current -10 to -20 temps this week. But **** it’ll be 61 on Sunday! Too bad the lakes are frozen!
            • Wayward
              • Apr 2013
              • 424
              • Northeast
              • 2022 XStar
              #21
              Thanks Guys! It was a heck of a project!
              • Bevostein
                • Jun 2008
                • 523
                • Frisco, TX
                #22
                Wayward WOW. I remember seeing the outside shots of your place when you listed your G23 and was impressed with your rolling boat lift. The inside takes it to a whole other level.
                Here is our "garage".
                • Wayward
                  • Apr 2013
                  • 424
                  • Northeast
                  • 2022 XStar
                  #23
                  Bevostein I don’t know, your’s is pretty awesome as well!
                  originally, I was trying to build a regular boathouse setup similar to that, but state and local permitting agencies wouldn’t let me. With that being the case, I got creative and combined my boat house with the new house. At the time, the rules were written in such a way, that they couldn’t prevent me from building it. The permitting guys were pissed, especially the state DEC. Their latest rules were written specifically to keep structures like this from being built. However they accidentally left a clause in there that makes existing impervious surfaceareas exempt from permitting. My lot happened to have a 50x60’ existing impervious area that was pushed right up to the water. They couldn’t do anything to stop me, as long as I didn’t build in the water. They are looking to modify that rule now.......
                  I’m kinda glad it worked out this way. I love having the boat in a dry bay. It takes less than 2 minutes to put the boat away (version 1.0, and 1.1 winches were much slower and took about 5 min. Version 2.0 is much faster and I incorporated a soft start/stop). I can clean/wax/service right in the boat room. I’m not constantly battling dust, or pollen, or water from windy rainstorms. The best part is that I don’t have to pull the boat in the winter, or winterize it. The only thing I have to do for winter storage is shut off the breaker for the winch systems, and walk away.
                  • Evening Shade
                    • Apr 2015
                    • 1295
                    #24
                    All of the above garages and docks look awesome to me!
                    • surroundsound64
                      • Jul 2005
                      • 2147
                      • Longview, TX
                      • 2018 230 1981 Ski Nautique
                      #25
                      Originally posted by Wayward View Post
ID:	575409 Click image for larger version
                      Life goals.
                      2018 SAN 230
                      1981 Ski Nautique
                      Sold - 2011 Sport 200V
                      Sold - 2000 SAN
                      • thejean
                        • Aug 2017
                        • 364
                        • Calgary, AB
                        #26
                        If I put mine in my garage I’ll block access to the house and exterior door. Ugh.
                        I thought about reversing it but the driveway is 6% and I would need to install a winch in the shop floor to pull it up the driveway. Doable but a pain.
                        • SoCal G-Man
                          • Apr 2016
                          • 329
                          • Westlake Village
                          • 2019 Super Air Nautique G23
                          #27
                          Wow! These are nice setups. Thanks for sharing.
                          • Rockymtnsurfer
                            • Nov 2017
                            • 404
                            • Steamboat Springs Colorado
                            • 2003 210 SANTE
                            #28
                            Grateful
                            • Tallredrider
                              • Oct 2014
                              • 1026
                              • St. George, Utah
                              #29
                              Not picking on anyone, but you guys have some of the cleanest and emptiest garages I have ever seen in my life. Am I the only guy with a garage full of tools, spare parts, extra flux capacitors for the boat, a motorcycle, motorcycle maintenance supplies, shelves and shelves of cleaning supplies, 2 radios, camp chairs, a couple of tents, a backpack, cooking stove, etc? I've got some pictures that I will post in a bit, but I am embarrassed at how much stuff I have compared to some who have such neatly manicured garages.
                              • Rockymtnsurfer
                                • Nov 2017
                                • 404
                                • 2003 210 SANTE
                                #30
                                LOL...........not showing you my garage
