Anyone use Wakemakers Plug n Play in A GS20?
  • cbeitel123
    • Mar 2017
    • 60
    • Los Altos, CA
    • 2017 GS20
    Interested in your impressions on the Wakemakers Plug N Play ballast.
    Heard that initially it didn’t work too well in terms of integration of Fill/Drain and LINK Panoray.
    Thx in advance.
  • Evening Shade
    • Apr 2015
    • 1295
    I’m interested in hearing impressions as well.
    I ordered all the fittings to build my own piggy back system this winter.
    I do know that the current system Wakemakers is selling for the GS20 fills the stock ballast and piggyback sacks at the same time rather than the old way of using the stock ballast over flow to fill the piggyback sacks.
    I would’ve just ordered the piggyback kit from Wakemakers rather than make it myself, but they wouldn’t sell just the hoses/fittings pre-assembled. The only way to get the hose kit is to buy the whole kit including the sacks. I didn’t want to spend $500 on the whole kit since I already have sacks and all hoses I need.
    • mikenbike211
      • Sep 2016
      • 447
      • New York
      • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
      You can’t just add weight to the rear on this boat and call it good like on everything else. You will need almost equally distributed weight front to back
      • cbeitel123
        • Mar 2017
        • 60
        • Los Altos, CA
        • 2017 GS20
        I typically run the belly at 40-60% with the stock rear ballast full. When I add sacs to the rear, I bump up the belly. Interest in the Wakemakers kit is I don’t have to mess with the fatsacs.
        • mikenbike211
          • Sep 2016
          • 447
          • New York
          You ought to give the “lead” bags a try ... I love them, after selling my 20 I’m putting them in my 22
          • Kinloch
            • Jan 2016
            • 46
            • New zealand
            • 2018 gs20
            We plumbed the kit in, was relatively easy to do but the 650 bags add too much weight to the rear. We run standard motor and prop so are going to try a different prop. I find it surfs best with all factory full and about 200pounds in each locker. Nss0 ncrs 3-4 17.2kph. This is with two adults and one surfer, I’m about 220-230 pounds.
            • mikenbike211
              • Sep 2016
              • 447
              • New York
              I ended up with acmes 1617 recommendation for my weight and use..... 700# over stock and 6 people in the boat..... it did much better than the stock 1235. I would contact them, they are great to work with.
              • Evening Shade
                • Apr 2015
                • 1295
                Your GS20 came stock with an Acme 1235? Mine came with an Acme 645 (13.25x16). I have a spare 1579 (13.5x14.25) that I'm going to switch to this spring.
                • mikenbike211
                  • Sep 2016
                  • 447
                  • New York
                  Ahh no your right, I had the 1235 on my old 211 ( worked great with all the extra weight)....you’ve got a gs22 now right ?
                  • Evening Shade
                    • Apr 2015
                    • 1295
                    No I still have my GS20.
