Hey guys, need some help on tower parts. The tower I just got is missing some hardware. Came off an older 210. I need the bolts that are on the tower hinges when folded (it's missing one), the knobs to release the tower for folding, and the mounting screws/bolts. I tried Wayne at NDT but said they weren't the manufacturer of that tower. Any guidance? Checked NautiqueParts but didn't see anything. Pic below. Sorry, no idea why it's sideways. <--- Fixed by admin
This link will get you to the page with tower knobs. I’m pretty sure they have the one you need. PND discount code
https://www.nautiqueparts.com/?s=TOw...t_type=product
not sure on hardware but I’d give Townsend a call at NP. Or email him the pictures of hardware you need, he could point good in the right direction I believe.2009 Super Air Nautique 210 TE
1989 Sport Nautique
It’s an FCT 2nd gen
here is a great link identifying the different towers.
https://www.planetnautique.com/vb5/f...control-towers2009 Super Air Nautique 210 TE
1989 Sport Nautique
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
Thanks Jeff. Got it. Hey, what type of bolts do I want to attach the tower to the fiberglass and backing plate? Any idea on thread or bolt length? Looks like I'm going to be on my own for these as NP doesn't have them. The bolt on the hinged portion I have one of and will just find another, shouldn't be too hard. Question on that hinged alan bolt...is there supposed to be any type of "nut" on the other side or does it just pressure fit. I'll attach a pic of what I have for the hinge bolt.
There is not a nut that holds the socket head cap screw. It should thread from the outside to the inside and thread into the inner part of the tower frame. You should be able to at least determine the size and thread pitch and order a stainless steel on from somewhere.
As for the tower to the boat, it should be with stainless bolts, washers and nylock nuts on the bottom of the gunnel. I don’t remember the sizes for those.
I just went though all of this. Yes it’s a FCT2. The knobbed bolts have a c clip that you’ll need snap ring pliers to remove. You get access to that from above once you take the upper portion off. Take any bolts and washers to a local Fastenal or hardware store and they can get you fixed up with new stainless hardware.
An no there is not a nut for the bolt you pictured. It just threads into the tower.
Originally posted by gobluemike2142 View PostThanks fellas, much appreciated. Hey Brit, how long on the bolts for the tower to mount to the boat. Figure the backing plate will be what, 1" thick maybe, so maybe 2" or so long? I guess I can play with it.
