So I took my 07 SANTE 220 out of storage for the summer, hooked it up to the fake lake and it fired right up first try. I had to have an oil and impeller change done at the local marina so I dropped it off there. They called me and said the starter was bad which I found odd since it just started without an issue. So I figured no biggie I took it home and swapped out the starter. When I tried to start it again the engine would crank then seem like it got jammed and lock up. It would not start and definitely does not sound good when it locks up. Is it possible they put the timing belt back on wrong? What could they have possibly screwed up and what should I be worried about in the future? I am dropping it off today for them o look at tomorrow again.
If it were mine I’d probably pull the plugs and try to turn it over by hand. I guess it’s possible they put the serpentine belt on wrong so maybe the water pump is not working correctly and it overheated but not sure you can do that with the correct size belt.Last edited by Shawn Henderson; 05-05-2019, 11:10 AM.
A d m i n i s t r a t o r
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
I agree. Pull the spark plugs and turn it over by hand. I have a bad feeling you're going to find water in the cylinders.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Check the starter for rotation direction. I remember when I was younger we changed the starter on our older Mastercraft and it wouldn’t start, only to realize the starter was wrong. Same model, just different rotation.
Not sure if this is a possibility in newer engines, but may be worth a look.
Sent from my iPad using Tapatalk2012 SANTE 210 (it's official)
2008 SANTE 210
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
Water in the cylinders (causing hydrolock) could be caused by lots of things. My immediate concern is that the engine may not have been winterized properly, and if cracks happened in the right place(s), cooling water could be forced into the cylinders by the pressure of your fake-a-lake hose. That water won't compress, and will cause the engine to lock up. Removing the spark plugs will allow the water to escape, and the engine should spin again.
If the starter really did go bad, it is possible that the new starter is the wrong rotation, like noted above.
Who worked on the boat and said the starter was bad?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Sounds like it is hydro locked. I expect that your impeller is bad and it was just starting to get hot when you started it and turned it off. Upon this sequence the motor dieseled and suck water back into the cylinders.
Sent from my iPhone using PLT Nautique2008 210 SANTE
I agree on the sounds of hydrolock. But that’s a pretty crappy diagnosis by your marina to call it a bad starter and move on. Did they winterize it too?
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
Charles is right. No way a corroded cap would cause the engine to lock up. There's more to this story.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Sep 2016
- 447
- New York
- 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
Originally posted by Gwojcik7I agree something doesn’t feel right about this. I don’t think their telling me the whole story. I may have the certified nautique dealer send a technician out to do an overview on the engine and try to foot the bill to the marina.
Originally posted by mikenbike211 View Post
A corroded cap CAN cause this issue. If it’s corroded enough, the spark can jump to a different cylinder causing the crank to be forced in the opposite direction therefore seeming like a hydro lock.
-Charles
Sounds like it was hydro locked.. I had a 07 220 and blew a belt while riding.. changed the belt on the water and it was locked up. Brought it home and changed the starter and same thing.. Pulled the plug and spun it over and she was full of water. Changed the oil and she ran for another 5 years no issues.
Yes you have to remove the serpentine belt to change the impeller. Perhaps the term they are using is incorrect.
