Wakesurf Edge from Liquid Force on 2002 SANTE
  • Blair02SANTE
    • Jul 2008
    • 8
    Has anyone used the Wakesurf Edge from Liquid Force on their 2002 Super Air Nautique?
    Any other recommendations other than buying a new Nautique?
    Cheers,
    Blair
  • gdhall
    • May 2011
    • 122
    • Bainbridge, Ga
    • 2003 SANTE 210
    I use a DIY suck gate on my 03. The way the back of the boat angles in makes it tough but it's almost an identical angle as the surf gates that are out there if you use one that has a 90deg angle then put it behind the angle on the boat.
    • 03SANTE
      • Sep 2018
      • 166
      • PA
      • 2003 SANTE
      Having good luck with Mission Delta on our 03. It has a way to reverse mount the plate so it can be back as far as possible on the hull before the angled part.
