Plywood Engine Slider Panels
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • Steamboat Springs Colorado
    • 2003 210 SANTE
    I need to switch out my engine slider panels on a 03 SANTE. I have a ton of nice 3/4 in around mu shop and some metal. Didn't know if anyone has done this with ply....or is it a bad idea. I see a lot of posts with HDPE board or purchase of walls from Wave.... Any thoughts or comments? Thanks D
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • 2003 210 SANTE
    Also...was hoping to keep a two piece system....being it's easier for access.
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      IMO, the biggest issue you are looking at is the high possibility of mold growing on the plywood and why HDPE is normally used. 3/4" plywood will be plenty strong when you add some support brackets, but it will absorb moisture, start delaminating/deforming unless you seal it with several coats of a really good primer and paint, especially all the outside edges (possibly something like rhino liner could work well and could last longer too). My guess is no matter how well you seal it you will be looking to replace it every 2-3 years since wood just doesnt hold up well in a marine environment. Definitely doable tho if you prep it right
      • shag
        • 2217
        There is a reason that Correct Craft stopped using wood... That said you might get a year out two at the most out of something...
        • Rockymtnsurfer
          • Nov 2017
          • 404
          • 2003 210 SANTE
          boy I feel dumb....makes total sense......thank you all for the knock on the head!
          • MTRBTR
            • May 2012
            • 485
            • MT
            You live in a dry climate. It’s probably fine. Most boat owners live in a lot more humid climate that you. It’s not like they are structural. I wouldn’t hesitate. If they rot out it’s a cheap replacement.
            2006 SV 211 (Sold)
            97 Sport Nautique (Sold)
            89 PS 190 (Sold)
            75 MFG (Sold)
            • funkster
              • Mar 2011
              • 199
              • Washington,state
              • 87' Ski Nautique(sold) :( & 98' Super Sport
              Or just apply some cheap resin, they would last for years. Another alternative (slightly cheaper) besides HDPE is trextrim composite fascia board, basically water proof and you can get it at lowes. I’m going on year 3 and they’re holding up nicely.
              • Rockymtnsurfer
                • Nov 2017
                • 404
                • 2003 210 SANTE
                Thanks for the advice.....I think I am going to give it a go at least for the next month or two.....on a tight budget and the 750's are making me nervous. I was thinking a two piece like the one in there, and then a cross bar diagonal corners bottom to top......one or two with bolt on engine side. Feel free to chime in is people think this is a bad idea.
