Faria Gateway Replacement Question
  • 03SANTE
    • Sep 2018
    • 166
    • PA
    • 2003 SANTE
    2003 Air 210, seems like my gauges are on the brink. I plan to take off the gateway and see if there has been water intrusion. Looking ahead, if I would need to replace the box with the new system that no longer uses the gateway, will my Perfect Pass still work? It is the original, I think called digital pro and works perfectly to this point. The instructions from Nautique parts say to contact Perfect Pass for some bypass kit but I wasn't sure if that applied to all of the years that this fixes. Thanks in advance!
