Factory engine flush kit
  • ducatidesmo
    • May 2019
    • 115
    • Sammamish, WA
    • 2018 230
    Hi All,
    I'm curious, what does the factory engine flush kit look like? is it literally just the Perko flush kit? Does anyone have an image of their flush kit (either the option or coastal edition) that they can share?
    Thanks!
    -Derrick
  • GMLIII
    • May 2013
    • 2798
    Originally posted by ducatidesmo View Post
    Hi All,
    Thanks!
    -Derrick
    I don't have an image handy but on my 2017 G23 Coastal Edition , it is literally a female brass garden hose end fitting just on the outside of the engine divider then a hose which has an open and close 90 degree handle. Very simple system
    • ducatidesmo
      • May 2019
      • 115
      • Sammamish, WA
      • 2018 230
      Thanks GMLIII, If you have a moment, woudl you be able to snap an image?
      • GMLIII
        • May 2013
        • 2798
        Yes but will not be till this weekend when I'm back at the lake
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          Yes, simple but that's not the whole story, it goes from the back of the boat to shutoff (as mentioned above) by hose to a brass tee between the strainer and i believe the raw water pump. You gonna need that part...maybe nautiqueparts has it.
          I am sure GMLIII will give you pics of everything you need.
          • GMLIII
            • May 2013
            • 2798
            Click image for larger version  Name:	9046FA44-9C66-4761-A0AA-B8750C2F5816.jpeg Views:	0 Size:	35.0 KB ID:	586045 Click image for larger version  Name:	2CC81599-F835-4962-87B7-41D850AD21D4.jpeg Views:	0 Size:	42.9 KB ID:	586046
            Here is the stock factory flush kit on my G23 Coastal Edition. 1st picture shows the handle to turn the water flow on or off, Picture 2 is the female garden hose fitting just on the outside of the engine divider. Very simply system
            • ducatidesmo
              • May 2019
              • 115
              • Sammamish, WA
              • 2018 230
              Ahh OK , you hook the hose up to the fitting... where is it at, that looks like the inside of one of the lockers. also, where does it T into the raw water line?
              • GMLIII
                • May 2013
                • 2798
                Yes hook hose up to fitting . Fitting is at top of starboard stern locker , very easy access. I may need help from the experts to answer part two of your question . Since this is a Coastal model I don’t have raw water but fresh . I think only the manifolds have water but not entirely sure. This is s partially close system cooled with antifreeze and a heat exchanger . Don’t know if that helps you but I gave it a try .
                • ducatidesmo
                  • May 2019
                  • 115
                  • Sammamish, WA
                  • 2018 230
                  The way the shop has done it was pretty ingenious... they plumed a fitting on the strainer bowl, hook up the hose to it, turn it on. and there you have it!
                  Thanks yall.
                  I'd love to see an image where it T's in, costal or not.
                  • GMLIII
                    • May 2013
                    • 2798
                    Thanks yall.
                    Ok I’ll trace the hose in the AM and see where it Ts if that helps
                    • scottb7
                      • Aug 2011
                      • 2198
                      Yep, you gonna need the pic of where the t is relative to the strainer. GMLIII will find it tomorrow, and then it will be great to have all the pics in one thread. Let us know where you source the T.
                      • GMLIII
                        • May 2013
                        • 2798
                        N
                        I tried tracing the T handle hose and it ending up going below the Vdrive area in which I could not see the hose anymore. Somehow it has to T into strainer hose but I gave up . Nonetheless here is the part you need from Perko
                        http://www.skidim.com/FLUSH-PRO-1/productinfo/DP6/
                        • scottb7
                          • Aug 2011
                          • 2198
                          No that is not it. That is what is used when you don't use the handle shut off. That one is more automated but less reliable. Not what Nautique uses.
                          You have to get low, lay on the floor of the boat, find the strainer, and take the picture from there.
                          • GMLIII
                            • May 2013
                            • 2798
                            Originally posted by scottb7
                            Pics
                            Sent from my SM-G950U using Tapatalk
                            The hoses on both sides of the drainer are different diameter hoses then the hose coming off the T handle . I’m guessing the T handle hose must T-bone into one of the strainer hoses at some point but I can’t find it due to difficult placement and it is pitch black in that area of the engine. Can’t take picture and hold flash light simultaneously. Sorry
