Battery Switch Question
  • ducatidesmo
    • May 2019
    • 114
    • Sammamish, WA
    • 2018 230
    Hey All,
    Looking at swapping my Blue Sea Systems four position switch to a three position switch (on and both) which is completely isolated, along with a charging circuit. My question is, these are 65AMP switches.... Don't we have 110 AMP Alternators? This is an 18 230.
    Thanks in advance.
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    The 6011 mini is 300A continuous. You do know that an ACR/VSR goes along with that switch change?
    • ducatidesmo
      • May 2019
      • 114
      • Sammamish, WA
      • 2018 230
      That was the one I was looking at, why do they advertise "for 65 amp alternators" I guess is my question. with that said, it's also the size that's in our boats.
      The exact kit is below:
      https://www.bluesea.com/products/764...tery_Kit_-_65A
      • ducatidesmo
        • May 2019
        • 114
        • Sammamish, WA
        • 2018 230
        OOOOOOOOOOOOOOHHHHHH.... It's not the switch... it's the relay. I feel like a big dumb animal now.
        -Derrick
        • MLA
          • Dec 2009
          • 1312
          Just buy them a-la-carte and get the 6011 switch and 7610 ACR
          • functionoverfashion
            • Jun 2017
            • 509
            • New Hampshire
            • 2003 SANTE
            Just a thought, if you only want a way to combine the batteries as an emergency jump-start, you can just use a simple disconnect switch between them. ON = connected, OFF = separated. Then the charging relay keeps the second battery charged. It's a little simpler to wire it up that way, if all you want is the ability to combine or isolate.
            • ducatidesmo
              • May 2019
              • 114
              • Sammamish, WA
              • 2018 230
              I'm actually kinda surprised they only setup the G boats with the 6011 and a charging relay. All the other boats use .. well what I got.
