2013 210 music volume stuck
  • Cadesun
    • Aug 2007
    • 99
    • Lake Geneva, WI
    • 2013 SAN 210 TE,,, 1998 Super Sport - sold
    My 2013 210 sometimes cranks music to full volume when accelerating and neither Linc or the Clarion head unit will respond to volume or mute commands. I have to kill the engine and battery to reset. Many times it will just do it again even after restart. Any suggestions?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Something is out of whack with the auto-volume. Try disabling that and see if it stop cranking up on you.
    -Charles
    • Cadesun
      • Aug 2007
      • 99
      • Lake Geneva, WI
      -Charles
      Thanks, do I access that through Linc or the head unit menus? Sorry, just upgraded from a ‘98 super sport so lots to learn!!
      • d_nodixon
        • Sep 2008
        • 475
        • Hammond, LA
        • 2013 SAN 230
        I had the same problem and fought it a while...on both my 06 and 13 models. Replaced, cables, remotes, turned off auto volume and disconnected from Linc. Still had the same issue. I settled on the problem being the Clarion head unit. Switched out to JL MM50 with the MMR40 remote.... no problems since, but only 4 months into the switch.
        Sent from my Pixel 2 using Tapatalk
        2013 SAN 230
        2006 SSN 210 (SOLD)
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          Yours was a Clarion in 2013 230? Mine is Polk in 2014 G21. Was switching from Clarion to JL plug and play?
          • d_nodixon
            • Sep 2008
            • 475
            • Hammond, LA
            • 2013 SAN 230
            Not plug in play at all, and no longer running through Linc(possible???). It took me a few go rounds with crutchfield b/c they did not have the correct cables an not familiar with it really. Should have went directly through JL.
            I tried to set up my own NMEA network so I could have two MMR 40 remotes, but that did not work so I settled with getting the JL cable to wire the single MMR 4O remote at the helm. Will be insalling the standard transom remote at a later date.
            2013 SAN 230
            2006 SSN 210 (SOLD)
            • Cadesun
              • Aug 2007
              • 99
              • Lake Geneva, WI
              Yikes! Do you think if I order directly through JL they would be able to walk me through the swap? The boat lives at the lake house so I only have access to work on it during weekends.
              • d_nodixon
                • Sep 2008
                • 475
                • Hammond, LA
                • 2013 SAN 230
                I can get you pointed vin the right direction if your ok with not controlling through Linc and have settled on the JL head unit. Will post some more info/details later. That. MMR 40 controller if quite useful
                2013 SAN 230
                2006 SSN 210 (SOLD)
                • d_nodixon
                  • Sep 2008
                  • 475
                  • Hammond, LA
                  • 2013 SAN 230
                  Screenshots / pics below. The cable needs power also, I tied into the same power cable that goes to head unit. The other two wires go to the same ground wire. This will allow you to connect the MMR 40 and you will have connections for two other remotes. Google JL support number, you will not find it on there website
                  2013 SAN 230
                  2006 SSN 210 (SOLD)
                  • Cadesun
                    • Aug 2007
                    • 99
                    • Lake Geneva, WI
                    THANK YOU!!! I had a couple stereo-inclined buddies mess with the settings and reset the Clarion over the holiday but same issue came back up so I guess I will have to replace the head unit. I just purchased this boat so I am gonna talk to the dealer tomorrow to find a solution. Problem is they are 350 miles from me so I can’t just take it in. Shame on me for not turning the stereo on during the test drive I guess.
                    • tke104
                      • Jul 2010
                      • 70
                      • Ice Coast
                      I had similar issues w/our 2012 210. The stereo randomly went to max volume while surfing. I wasn't manually accelerating, but was using the cruise so it might have been adjusting slightly. I tried a few things including turning off auto volume and disconnecting the stern remote to no avail. This happened maybe 5 times throughout the summer. My dealer suspected it was a bad cable from the head unit to the link. They replaced this cable in the off season and it has not happened since (about 4 yrs). I also had NSS installed that off season which required a software update; I am not convinced it was not the software update that fixed the problem.
                      • nautiques4life
                        • Jan 2009
                        • 696
                        • SoCal
                        Same problem, tried updating, happens less but still happens, worked with local dealer and Corp nautiques... no luck, next step likely headunit swap.e
