Center Locker Ballast 2000 SAN
  • SANCasey
    • Jul 2006
    • 68
    • Austin, Texas
    I have a 2000 SAN and want to know what people are using for the center ballast? I was looking at either the tube sac (10x16x62) or a seat sac (10x26x62) both by Fly High.
    Any recommendations on the best and biggest sac that will fit in the center locker?
  • wakefun
    • Aug 2003
    • 81
    • Oregon
    RE: Center Locker Ballast 2000 SAN
    The Skylon Locker Sack is what I use in my 2000 SAN - http://www.boardersparadise.com/merc...Category_Code=
    • NAUTIQUEjunky
      • Aug 2005
      • 61
      • KERR LAKE NC
      I use the Big Bump 750lb coverless sac Fits real nice.
      ISN\'T LIFE BETTER IN A NAUTIQUE!!!
      • lucey
        • Jul 2005
        • 95
        I just bought 2 Fly High Wedge sacs off ebay for 100.00. I was thinking about their locker sac (370) but can you get more weight in the locker than that ?
        • MHayes
          • Aug 2004
          • 830
          • Roswell, GA
          If you read the 2 posts above yours, you can find the answer to your question.
          2001 Air Nautique
          • lucey
            • Jul 2005
            • 95
            I guess i should have been more clear. Does the locker hold a completely full 370 lb or 750 lb sack ? I see some people have the 370 and the 750. With a 750 can you fill it up full or do you have to run it partially empty.
            • Laptom
              • Oct 2003
              • 876
              • Eindhoven, Netherlands
              I have a Launch Pad 560lbs sack and can compleetly fill it if I want (mostly fill it till 350lbs, because that is enough for us). And still has some room in the length. So if you find a sack with the same diameter but longer, you can put about 700lbs in it.
