Originally posted by Skidave
View Post
- May 2010
- 538
- Lake Tahoe
- 2014 210 2019 GS22, 2017 GS20, 2000 Air Nautique
i just picked up my boat from winterization with oil change. the invoice said Rotella 15-40. I questioned them, and stated I thought there was a change from PCM. They said they were not aware of the bulletin.
Should I take the bulletin to them and have them change it or let it slide until next oil change?
Also, is there a PDF version of the bulletin I can print out?
Thanks
- Mar 2002
- 16526
- Lake Norman
- Mooresville, NC
It probably won't hurt it, and if it does, they're a dealer, so they should be responsible.
They should certainly be aware of the bulletin. Kinda scary that they aren't.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- May 2010
- 538
- Lake Tahoe
thanks guys, i think i will let it be and have them change it at the beginning of summer. I will point out the bulletin again.
the image posted on this thread is super blurry when printed. can someone post a clear version or the pdf?
thank you
- Apr 2015
- 1295
- Martinez, GA/Lake Greenwood, SC
- 2017 GS20 Previous: 2011 SAN 210, 2007 Malibu Wakesetter 23LSV, 1995 Cobalt 200
This oil fits the bill. 5w-30 and Dexos certified.
https://rotella.shell.com/en_us/prod...ngine-oil.html2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
- May 2013
- 2795
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
Originally posted by Evening Shade View PostThis oil fits the bill. 5w-30 and Dexos certified.
Possibly who knows for sure. I would find it hard to believe that using this oil is going to have a detrimental effect on the engine. Everything in the specs and documentation show nothing but better than the standard with no cautions of using it in any application that the non synthetic versions.
- May 2013
- 2795
Originally posted by bturner View PostPossibly who knows for sure. I would find it hard to believe that using this oil is going to have a detrimental effect on the engine. Everything in the specs and documentation show nothing but better than the standard with no cautions of using it in any application that the non synthetic versions.
I jumped from the 15W-40 Rotella in the engine originally (on my third oil change) to Rotella 5W-40 T6 full synthetic. I called PCM to discuss as I did this; while they thought this was overkill to use full syn, they said it was fine to use. I will stay with this oil. I change way in advance of the hours requirement, but not in advance of “120 days” as this bulletin advises. I’ll sleep fine with my plan.
