You have plenty of weight, I think the key ingredients have already been mentioned above.....but I think you should try to focus on the below 2 things next time:
#1) LIST the boat a little bit to the surf side (try 350lbs or so less on the non-surf side). Even with a shaper, adding some list crabs the boat a bit more and will increase the push of the wave. Trust me, it makes a difference and your comment above about how "turning slightly to surf side will increase push when you are surfing" further backs this up since as you turn into the wave, the boat lists itself.
#2) Still use the suck gate of course....but note its position once under way (at surf speed), you need the top of the suck gate to protrude out of the water some when at surf speed, it will produce a rooster tail of water but this disturbance is needed since if the suck gate is buried under the water you will lose half of your available "wave push" even if the wave looks good back there.
For speed, you want between 10.8-11.4mph, play with this as speed can make a big difference...make sure you also play with the center adjustment that brings bow up/down. Start at the middle setting and go from there but bow higher = taller wave, and bow lower = longer/shorter wave.
Make sure you water depth is 20ft plus
All that said, you should not be dropping the rope till you can ride for 30-60 seconds with slack in the rope. Surfing is technique and takes water time. Many people think they are doing it right and its a wave issue....but then see themselves in video and realize that they had the board pointed away from the wave rather than into it. May also be worth taking some video of yourself since you can watch it later and SEE what you are doing, I was able to progress in many areas of surfing by watching myself on video.
Once you have wake surfed enough to "feel" the wave you will be able to ride any wave ropeless.
