G23 wakeboard setup
  • FEVB
    • Jun 2017
    • 68
    • Brazil
    • G23 2019 450
    G23 wakeboard setup
    Hi all for a meaty and big wake what is the recommended set up - stock ballast, NCRS setting, additional weight etc. Any feedback is greatly appreciated. Have the H6 in my G.
  • Mahnal
    • Apr 2019
    • 92
    • Bowling Green, KY
    • 2014 SAN G25 - 550
    There are a few other threads on this. Full ballast, 800 lbs of lead and or crew, 11.3-11.6. NCRS 2 or 3, NSS 3 or 4.
    • Mahnal
      • Apr 2019
      • 92
      • Bowling Green, KY
      Lead needs to be 150 to 250 biased to port. Most of the weight mid boat, then some in back locker, and a little up front. For example, 200 under port flip seat, 50 each side of bow. 100 each stern locker, 150 each side under seat.
      • 99bison
        • Jul 2014
        • 135
        • Location
        What hull, 16+?
        What shape you want... steep and big?
        Ncrs 5
        Full stock + 300 nose, 250 mid, 150 rear. With the mid and rear biased 200 lbs to port.
        Or just go stock.
        Ncrs dictates steepness.
        • scttp
          • Sep 2015
          • 93
          • Duluth, GA
          • 2015 G
          2015 g23 w 450. When we want max wake: stock ballast full, ncrs all the way steep (not deployed), 400lbs of lead around cabin (none in nose), and a 350lb bag under each side seat. So about 1100 over stock. 23mph 75ft rope. Gets on plane easy with small crew...starts to struggle around 6 or 8 people in boat.
          • 99bison
            • Jul 2014
            • 135
            • Location
            Originally posted by 99bison View Post
            What hull, 16+?
            Ncrs 5
            Full stock + 300 nose, 250 mid, 200 rear. With the mid and rear biased 200 lbs to port.
            Or just go stock.
            Won’t let me edit... 200 not 150 rear.
            • FEVB
              • Jun 2017
              • 68
              • Brazil
              • G23 2019 450
              What hull, 16+?
              Ncrs 5
              Or just go stock.
              Tks
              19 G23
              • 99bison
                • Jul 2014
                • 135
                • Location
                Originally posted by FEVB View Post
                Tks
                19 G23
                19 is what we have as well.
                • Kmayotte
                  • Apr 2010
                  • 819
                  • Lake Winnipesaukee, NH
                  I run a 2016 G23
                  Full Ballast plus 4-5 adults evenly distributed
                  NCRS 5
                  22 mph
                  65ft line length
                  Don't discount line length and speed, their as important as ballast and play a big part in the feel of your pull. When I first got the boat I was used to a more "old school" setup and was riding at 23.5 mph and 75+ ft which is what the older boat required to get to a super firm meaty wake. Slower and softer is so much better on these big boats now. The wake and lip is super firm & meaty at 22mph on the G but the landings and impacts are so much softer and more forgiving.
                  • jphdrake
                    • May 2014
                    • 32
                    • Dothan, AL
                    • 2017 G23 550
                    For the best "meaty and big wake" for wakeboarding for the G23.
                    300lbs lead in the bow
                    300lbs lead under port observer seat
                    800lbs sack on the floor in the cockpit
                    200lbs lead in the rear most part of the stern compartment (adds some extra pop to the lip)
                    NCRS 5
                    Full stock ballast
                    speed 22.9 mph
                    line length 75,78,80ft
                    We have a small crew of driver and observer. As we add crew I will subtract weight to compensate for the extra weight from the port and starboard tanks if the crew is larger than 4 total people.
                    There are tons of great other options as you shorten the rope and slow the speed as well. For now this is the best overall combination we have found.
                    • GMLIII
                      • May 2013
                      • 2792
                      NCRS 5
                      Full stock ballast
                      speed 22.9 mph
                      That is a ton of weight. Your wake must be massive. With that weight and 550 engine, the marinas must love you when you pull up for a fill up
                      • jphdrake
                        • May 2014
                        • 32
                        • Dothan, AL
                        • 2017 G23 550
                        Yes this is not the most fuel efficient wakeboard wake for sure but the wake is huge and clean.
                        • FEVB
                          • Jun 2017
                          • 68
                          • Brazil
                          • G23 2019 450
                          Many tks! My rope length is 70 and speed at 22.2mph. Should I reduce a bit the cockpit floor sack?
                          NCRS 5
                          Full stock ballast
                          speed 22.9 mph
                          • Cpan13
                            • Jan 2016
                            • 339
                            • Canada
                            • Current - 2021 G23 … Previous - 2020 Supra SL450, 2015 G23, 2014 G21, 2012 Epic 21V
                            Not much to add here. Just happy to see a wakeboard thread.
                            The G’s love weight. Just add more everywhere until whichever motor you have can’t handle it.
                            • Mahnal
                              • Apr 2019
                              • 92
                              • Bowling Green, KY
                              Who needs a double up when you have a wake that big.... Rock on.
                              I am a beginner to Intermediate and 46. I had half ballast and 700# of lead ( for surf), and the wake was so huge I asked my wife to drain the ballast.
