Originally posted by RDT-G23
View Post
I suspect he means that most C-clamps are 1 1/8" in diameter and you can't make it fit the 1 1/4 shaft. It is nothing that a grinder can't solve, and that is what I did to my old puller to make it fit. But you can't do that at the lake once you bust up your prop. I would also verify the length of the hub, as it may not fit if the hub is too long. That would suck.
Originally posted by Tallredrider View PostI suspect he means that most C-clamps are 1 1/8" in diameter and you can't make it fit the 1 1/4 shaft. It is nothing that a grinder can't solve, and that is what I did to my old puller to make it fit. But you can't do that at the lake once you bust up your prop. I would also verify the length of the hub, as it may not fit if the hub is too long. That would suck.
Head to head Paragon drag race video finally finished. If the below link doesn’t work, check out N3 Boatworks YouTube page. They do a lot of interesting things like this from time to time. Great dealership to work with.
Originally posted by memerr View PostHead to head Paragon drag race video finally finished. If the below link doesn’t work, check out N3 Boatworks YouTube page. They do a lot of interesting things like this from time to time. Great dealership to work with.
https://youtu.be/tIej0Z5BPzc
Motor comparison was nice, but I'm more interested in how you got a dark air dam? hahahaah that's awesome
Like I said, N3 is fantastic to work with. The air dam is the only thing white on the boat and I couldn’t handle it. It’s a vinyl wrap done by the dealer.
Love the new design and fit and finish of the paragon but the new motor is really a over kill or need to fix something ,
on my paragon after 28 mph it starts to bob up and down in the front real bad to the point you have to slow down not sure why has any one else with a paragon experienced this
Originally posted by Eeleagle View PostLove the new design and fit and finish of the paragon but the new motor is really a over kill or need to fix something ,
Sent from my iPhone using PLT Nautique2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
Originally posted by nohlan_4 View Post
You have the ncrs plate in auto with no ballast when cruising like that?
