Nautique Releases G23 Paragon
  • nohlan_4
    • Jan 2016
    • 418
    • Canada
    • 2013 G23 450
    #421
    Originally posted by Eeleagle View Post
    There is a off ,lo and high setting no auto I believe I have be trying everything from high to lo to off , also been trying different ncrs setting with ballast weight in front yet still have the porpoise issue after around 28 mph any thoughts
    I meant that ncrs is actually turned on when cruising. Make sure the ncrs is set to 0 and in the high setting with zero ballast. Then report back. That should be baseline good. If not then add small amounts of front ballast until it goes away. If that’s doesn’t work then I’m not sure what else to try.
    • Eeleagle
      • Jun 2020
      • 5
      • Fresno ca
      • P23 paragon
      #422
      That worked thank very much appreciate that ,on the paragon the ncrs setting is the wave shape which should be at 0 for no porpoise thank you again
      • nohlan_4
        • Jan 2016
        • 418
        • Canada
        • 2013 G23 450
        #423
        Yup zero is fully deployed and nose down attitude. Your welcome! Happy boating! Still need to get on a P23 one of these days.
        • Eeleagle
          • Jun 2020
          • 5
          • Fresno ca
          • P23 paragon
          #424
          Come out some time check it out I’m in Cali
          • SteeleWake
            • Jun 2015
            • 32
            • Discovery Bay, CA
            • 2021 G23 Paragon
            #425
            For those with the newer Paragons (late 2020 or the 2021s that are being delivered now), let's hear some feedback on how the boat is performing? In particular wondering about the ZZ8 motor as far as power, fuel consumption, typical RPMs, any cooling issues, etc?
            • MG94
              • Oct 2019
              • 147
              • Il
              • G23
              #426
              I forgot all about the new engine once I took delivery. 550 has plenty of power for us but we run 3-4 people max most do the time
              • RDT-G23
                • Jun 2017
                • 589
                • TEXAS
                • 2020 G23 PARAGON I 2017 G23(sold)
                #427
                The engine has great power; the torque is especially stout. It runs at about the temp that other marinized GM V8s with closed cooling do, which is about 169 degrees. Surfing at ~11.5MPH happens at about 2,850 RPM. I haven't done any scienific fuel consumption studies, but it seems to be not too dissimilar from my previous H6. In short, it seems like a great power plant in the short time I have used it, especially for the P23 (weight).
                My only gripe has been (and remains) - PCM has no manual for the ZZ8 yet. Absurd. I talked to someone at PCM (I won't name the individual, but someone who was quite aware that it needed to be published). This conversation was ~120 days ago (at the time I took delivery of the boat with no manual). He agreed that "they need to get this done". Contrast that with the F250 I took delivery of in December; it was one of the first produced with the third generation Powerstroke. Did it come with a well-considered, thorough manual? Of course it did. Am I wrong to juxtapose boat and auto manufacture? Clearly.
                To illustrate how frustrating and wasteful this issue is, my dealer went to change an impeller on a P boat recently (for a Planet Nautique forum member here) and found that the pump on the ZZ8 didn't take the same impeller as the other 6.2L engines. This, in and of itself - isn't terrible; the issue is that he had nothing to tell him this in advance. He found out by pulling it from the pump. This all happened in a neighboring state... Bad juju.
                So, back to task - great engine so far. Owners getting hours on them will tell the reliability tale. I hope and suspect it will be a great powerplant for PCM and Nautique. They seem to do a good job engineering, but not supplying guidance manuals to the end user...
                • Kmayotte
                  • Apr 2010
                  • 819
                  • Lake Winnipesaukee, NH
                  #428
                  So who's going to list the first "used" Paragon for sale? Anyone seen one yet?
                  • MinnDakNautiqueFan
                    • Apr 2020
                    • 3
                    • Rose Lake West Central MN
                    • Looking for a SAN 210
                    #429
                    Marine Max Sail and Ski Austin has one listed in their Brokerage section.
                    • RDT-G23
                      • Jun 2017
                      • 589
                      • TEXAS
                      #430
                      I just got an e-mail from Ron Nace moments ago. He e-mailed me to let me know that PCM just published the manual; it is on the site now... Thankfully.
                      • Kmayotte
                        • Apr 2010
                        • 819
                        #431
                        https://www.marinemax.com/boats-for-...austin/7493895
                        250K w/ under 20 hours. I don't see these things depreciating enough in the next 10 years for me to own one. Oh well.
                        • NautiqueJeff
                          A d m i n i s t r a t o r
                          • Mar 2002
                          • 16550
                          • Lake Norman
                          • Mooresville, NC
                          #432
                          I see the ZZ8 Tech Info, but I don't see a manual. Am I missing something? I want to upload it to our site.
                          • RDT-G23
                            • Jun 2017
                            • 589
                            • TEXAS
                            #433
                            This is all we've got for now, which is much better than before; it certainly isn't the end of the story, I agree. It has fluid specs, impeller, etc.
                            • SteeleWake
                              • Jun 2015
                              • 32
                              • Discovery Bay, CA
                              • 2021 G23 Paragon
                              #434
                              Are you surfing with full ballast? If so, WOW as that is about 3600rpms on the XR7. Do you have the new 18x13.5 prop or did you do something different? Any chance you know what your RPMs are for empty/25mph (Back to Dock)?
                              • greggmck
                                • Oct 2014
                                • 795
                                • Bellevue WA
                                • 2023 Paragon G23
                                #435
                                Keep in mind the ZZ8 is paired with the 1.5:1 transmission while the XR7 used the 2.0:1.
                                Sent from my SM-G965U using Tapatalk
