I have an '03 SAN with PP version 6.4 firmware on it. At first, after reading the manual, it seemed that the higher you set the KdW and NN sampling values, the better everything should work, fully loaded. After several outtings and multiple frustrations with the PP surging all over the place, an idea finally came to me. I tried to see what the upper limit was on the settings and gave up after getting to about 500. Then I lowered it back down to some suggested settings and it seemed to work much better. Apparently, after a point, increaseing the values does not help. It may actually be worse depending on how the PP reads the digits. My question is, what it the maximum values that you can set these for? I'm running at 160 KdW and 120 NN right now.
Chad
Chad
