Coming from an extensive offshore fishing environment, I’m well aware of specific outboard engines with specific issues or years to avoid but I know nothing of the inboard wake/surf market. I’m in the market and shopping for a used boat and I see a number of relatively low hour <500 hr wake boats with replaced or rebuilt engines? The loads the boats are under, I’m sure play a role.
The general rule for outboards is 1000 hours or 10 years of problem free reliability with many doubling the hours within that 10 year period. However, In a salt environment, you’re often on borrowed time after the 10 year mark, regardless of the specific manufacturer.
I realize things can be all over the map, with some going 1000 plus hours with zero issues, but what’s the rule for a freshwater only inboard? Where does PCM stand amongst others in the industry. As far as build, and layout, I’m sold on Nautique over the others but don’t know much about PCM engines. Are there any specific models or years I should stay away from? I understand the PCM 5.3 may be one to avoid? Are there any models/years considered bullet proof? I’m considering both newer style, 2013 and up G21 or SAN 230, or an older garage queen with low hours <500.
I suspect improper winterization for northern boats might be a significant contributing factor to engine failures, so maybe best to avoid older used boats in northern climates?
