When we surf with the 211 it takes in water in the port side blower vent. I know we use more weight than recommended, but it is not an unrealistic amount. You would think when designing and testing the boat CC would test it beyond the maximum recommended thresholds to see what will happen. This is actually a safety issue because when the water comes in it rips the blower tube and fills the boat with water. If the blige is not on it could cause other damage due to water. The blower will then no longer work so there is now a gas fume issue until the tube is fixed.
There are a few ways around this i can think of; 1) less weight so it doesnt submerge or get splashed, 2) put duct tape over the vent, 3) surf on starboard side, 4) create a new vent cover that displaces water more efficiently. If anybody has created #4 let me know and i will buy one from you.
We like to surf on the port side and we like the extra weight, so currently we let the water come in and keep the bilge on. Of course our blower tube is thrashed. If CC knew about this they might re-think that port side blower vent. They could make the vent so when water splashed it that it didnt go straight in through the cheese grate holes. if the vent had some rear facing louvers it would displace the water better. They could also put the vents in the rear. I had the same problem surfing behind the 210 and we used to stuff a towel in the vent.
