SN 200 Fuel tank - how low can you go?
  • FMSKI
    • Aug 2010
    • 177
    • Sproat Lake
    • 07 SV211 Ltd 343 Sold (Ski 200, TSC1, 2001)
    Out on a great evening set today, lake was flat, minimal wind and other boats. Started at 10% fuel and came back on 0%
    I took 10 liters with me.
    On my modded TSC I could see what was in the tank at all times, which as great. Only had 40L capacity too.
    The 200 tank is opaque and I have no idea. So how low is 0% crossover point - anyone know?
  • Shamsra
    • Mar 2020
    • 58
    • Austin, TX ~ Lake Travis
    • 2023 Supra SL Traded in: 2020 Nautique 200
    You are brave FMSKI . I start getting anxiety at 25%, so I'm hoping to never know the answer to your question.
    • Stevemo14
      • Apr 2019
      • 691
      • Columbus, OH
      I can tell you from personal experience that when you can hear the FCC humming, its time to shut her down!!!
      • SilentSeven
        • Feb 2014
        • 1877
        • Bellevue WA
        • 2004 Nautique 206
        We try to ski with tank levels around a 1/3 down to an 1/8 just to keep the boat light. Once the dash gauge gets lower than that, my reward to risk meter inverts and I start looking for fuel.
        Bellevue WA
        • CHassmann
          • Jul 2004
          • 513
          • Holiday Lakes, OH
          We ran out of gas twice this season. I don't know about the 200, but I hate the L-shaped tank on our 2002. There is no chance for an accurate gauge reading unless the tank is full. I used to say that as long as the gauge moves when we accelerate we were okay, but that back-fired on me. Fortunately, we live on a relatively small lake and we were not far from the house when it happened.
          Ski on dude!
          • Kenboat
            • Sep 2021
            • 38
            • Traverse City, Mi
            • Zodiac 5.5 open RIB and 2012 Andy Mapple 200 CB
            I wonder if the boats have a fuel pump in the tank? If they do keeping enough fuel in the tank helps to keep the pump cool to provide longer life and when you run a tank dry more likely to such in junk in the tank that will foul the fuel filter.
            • MN Ryan
              • Aug 2020
              • 1268
              • Maple Grove, MN
              • 2007 SV-211 TE
              You guys are way more daring than I am.
              Sent from my SM-G970U using Tapatalk
              • shag
                • 2217
                I believe the OP's boat should have the pumps outside the tank as most, but know that many cars used to or still have pumps in the tank and that is a good reason, to help keep them cool. The high pressure one though, (I think that's the one) is inside the FCC which keeps it cool). I would be careful about always running low as you can pick up junk that settles in the tank, if it has a low pick up... I have seen this in cars awhile back. I try to never go below 1/4 tank. I mean a gallon of fuel is about 7#... 3-4 gallons of fuel makes 30# or less weight difference.
                • FMSKI
                  • Aug 2010
                  • 177
                  • Sproat Lake
                  The 200 tank seems to have a bit of well from what I can see. It looks like the tank is a good design. I've got 10L spare fuel under the bow at the moment. So far have not run out.
                  But my Catanium manifold looks like it might have a crack brewing, left side by the O2 sensor. There is evidence of a former leak. But the lake it was in is high ppm of particulates, might have self-sealed!
                  The 200 is running great at the moment but... IDK used boats you never know. Worst case have to drop in a new motor
                  • srock
                    • Oct 2008
                    • 1070
                    The big fuel filter would not prevent the crap in the tank from moving to the engine?
                    • vtjc
                      • Feb 2011
                      • 57
                      • Vermont
                      • 2008 Correct Craft Ski Nautique 196
                      @Kenboat A friend's MasterCraft with an in-tank pump has had a few failures as he always runs it low on fuel.
                      Previous Boats:
                      99 MasterCraft SportStar(95-97 ProStar Hull)
                      98 Moomba Boomerang
                      88 MasterCraft Powerslot
                      • DealsGapCobra
                        • May 2010
                        • 375
                        • Knoxville, TN
                        • Ski Nautique 200
                        I’ve had mine in the low single digits, did not enjoy that trip at all!
                        • shag
                          • 2217
                          Depending on the boat, there may be a basic filter between the tank and pump, then there in one inside the FCC. Stuff can still pass... Over time you would be surprised.
