I have a 1993 SN- I like the 96 dash better with the in-dash radio placement. Can I swap my dash in my 1993 for a dash out of a 1996 SN relatively easy? Thanks.
Tags: None
Can you? sure it's just fiberglass and plastic. Will it be relatively easy? depends on your skill set and your definition of easy. Anyway you look at it you're going to pull all the gauges, steering and dash components out of the boat so there is that. I would suspect some amount of cutting, grinding and fitting is going to end being in there as well.
thanks. so meaning they are not the same fit/mold and i just cant unplug wires off of one and into the other.
