Garage Clearance question
  • SnowCamo
    • Oct 2006
    • 5
    • Rockford
    Ok, so i am new to planettnautique, and nautiques in general. I pick up my 2006 210 team this week! :grin: i cant wait. My question is this. Will a 06 210 fit in a 7ft high, 8.5ft wide and 22ft deep garage. It sits on a ramlin trailer. I will be removing the swim deck, folding the tongue, and folding the tower. Any help is greatly appreciated. Thanks, Chris Weber
  • Andrew
    • Aug 2005
    • 891
    • Tuscaloosa, AL
    RE: Garage Clearance question
    gonna be close length wise
    • SnowCamo
      • Oct 2006
      • 5
      • Rockford
      yeah, i kinda figured that, i am actuallt more worried about the height. I dont know 7ft. is high enough. i can angle the boat a little in the garage to fix the depth problem. it is a 3 car garage with 3 individual openings.
      • taz
        • 13
        I have an 05 211 and had to get an adjustable hitch. When the boat is level or a little high in the front the folded tower rubs slightly.
        It's a bit of a pain to raise and lower but it beats having a 50k boat parked out side.
        • todda
          • Jan 2005
          • 281
          • Granite Falls, WA
          • 1999 SNOB
          Is the width going to clear the trailer? Up here in the NW/Seattle, most of our single door gararges are 8 ft, and if you go custom can get 9 ft width. I know our 196 won't clear width wise our 8 ft door. Good luck! We have a 3 bay garage (dbl door+1), 22 ft deep, and I can get our 196 in the dbl door at a slight angle, remove platform and swing-away tongue, and she fits with the 2500 Ram in one side, Pathfinder in the other!
          Todd
          Todd Aalbu
          1999 SNOB
          66.5" HO S2
          • MNSuperAir
            • Sep 2005
            • 591
            • St Paul
            • 2016 SAN 210
            22' should fit but it is close. Did you measure your garage to be 22' or is that what your built. What I'm trying to say is garages are built on outside dimmensions. A 22' garage is usually 21' to 21'4". I would be worried about the width. I went 10' wide so I can back it in late at night. I know it won't fit in a 8' garage door.
            2016 SAN 210
            2006 SANTE sold
            2001 SAN - sold
            1991 Sport Nautique - sold
            • SnowCamo
              • Oct 2006
              • 5
              • Rockford
              I measured it to 22' of useable depth. Also, i have exactly 8.5ft width and 7ft of height. It sounds like it will fit, it will just be a little bit of work. But like taz said, its better than having a 50k boat parked outside. Thanks for all the replys. Chris
              • Rick
                • Mar 2004
                • 1250
                • San Diego, Ca
                Chris if you search on dollies you will see my 2000 196. It fits in a 21.5" garage with the swim platform removed and the swing tongue. I put i on 4 wheel dollies and it lets me push it around to get every last inch if space in. You could do it after you back the tower in through the door.
                Nautiqueless in San Diego
                • jonfo
                  • 385
                  • Bellevue, WA
                  • 1990 SN 2016 G23
                  05 211 fits under 7ft garage with tower down, clears by a few inches.
                  -Jon
                  16 G23
                  07 220 TE
                  05 211 TE
                  95 SS (210)
                  89 SN
                  • speck
                    • Sep 2005
                    • 236
                    it will fit height wise, i answered your thread on wakeworld. you need it unhooked from your rig and on the ground with the wheeled jack and wind that down. mine just fits
                    • clubmyke
                      • Sep 2004
                      • 414
                      • so cal
                      i use a powermover which drops the nose down... pretty cool device to move the boat around..
                      • SnowCamo
                        • Oct 2006
                        • 5
                        • Rockford
                        Well, i picked the boat up last night, and it fit!! not much space, but enough to keep it out of the sun and weather! I will try to post pics within the next week if i get it out. (illinois weather isnt cooperating)
                        • wake_fun
                          • 1330
                          • CA
                          • 1995 Super Sport
                          Which company/model do you have?
                          How do you like it?
                          I'm looking at buying something to move my boat around.
                          Photo Album
                          Ballast Install 1
                          Ballast Install 2
                          Amp Install
                          PPass Install
                          Alternator Install
                          • Fast351
                            • Oct 2006
                            • 315
                            • Winsted, MN
                            • 2001 Ski Nautique
                            You must have a REALLY low trailer. I just measured the SV-211 at the dealer that I'm thinking about getting and it measured 7'2" where it was sitting, on a Prestige tandem trailer.
                            I'm in the same predicament. I have a 7' door (6'11" with trim). I'm about ready to do the deal but it has to fit in the garage. It'd be nice if I could just back it in with the truck instead of having to push it in by hand.
                            The dealer is going to let me take it home to check it. I hope it fits without too much effort.
                            Who else has dealt with this?
                            Some of the things that might work:
                            -Make sure garage door is all the way up.
                            -Low hitch on truck. I'm lucky here because my driveway is about 4" lower than my garage floor. Add that to the drop hitch on the pickup and the tongue should be good and low
                            -Dig concrete down where the tires will sit. Not ideal but doable.
                            -Lower profile tires.
                            -Move the trailer in the last few feet by hand. This might help:
                            Northern tool trailer dolly
                            Also how heavy are the fiberglass platforms? Is that a two person job or can a single non-wussy guy do it by himself?
                            2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
                            • SnowCamo
                              • Oct 2006
                              • 5
                              • Rockford
                              His 211 is probably on a ramlin trailer. I didnt know it, until someone told me, but ramlin mounts its bunks right on top of the trailer frame, eliminating some of the height of a normal bunk system. Maybe you could get your dealer to get you a ramlin instead if needed???? And one person SHOULD be able to take the platform off. I would be more concerned with folding the tower. I dont know about the 211, but on my new 210 it took 3 of us to lower it. No more putting the boat away by myself late at night!!
