Sante 210 short surf pocket?
  • Typhoon01
    • Aug 2022
    • 3
    • DFW
    I have always owned sanger V210's and they throw up a good surf wake but very short pocket. You are practically riding on the back of the swim deck. I have read several posts about the earlier year 2006 and older stating about the same thing. Is this accurate if somebody can help me before I buy one? Thank you
  • hondaprlud
    • Jul 2008
    • 568
    • OH-IO
    I had an 04 210. It's not as long as modern hulls. IIRC you'll want 40% of your weight in the bow to help lengthen it.
    19 SANTE 210
    08 SANTE 210 ZR6
    08 SANTE 230 ZR6
    88 Baja Ski Sport- First boat
    • 37tr3n5k
      • Mar 2022
      • 61
      • NB, TX
      • 2006 Super Air Nautique 220 TE
      You have to get your nose down. What weight setup are you running? What prop? How fast are you going?
      • swatguy
        • 1631
        • Midwest/ Northern IL
        • 2008 SANTE 210
        I’m the 06 210 will have the same issue as your V210. Have it spent a lot of time in a v10 and an og SAN it’s not really an upgrade at all in the surf category over the V210. If you make your way to an 07-up 210 the difference is worth every penny.
        like others have said to get a longer pocket , more bow weight is key. You de get a bit more freeboard with the SANTE when compared to the V210. But that’s pretty much the only advantage.
        • 37tr3n5k
          • Mar 2022
          • 61
          • NB, TX
          If you can find a 220, I have a 2007 220 SANTE that throws a huge, long wave after some fairly cheap mods.; (Less than 1.5k).
