What is the differnce between a 220 and a 226
  • Dan Batt
    • Dec 2022
    • 4
    • Fort Wayne IN
    • 2002 Air Nautique
    Looking to upgrade and have 2008 220 and a 2010 226 I am considering.
    1. What is the difference between a 220 and 226?
    2. I understand the 226 is a cross over what does that really mean?\
    3. Which would have the better surf wake?
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    The 220 is a 22ft wakeboard purpose built boat that actually does surf pretty well. The 226 is more of a crossover boat meaning they built it to wakeboard and ski. In my opinion the 226 will surf better and has the same hull as the 230. There is a member on here that makes knock off NSS plates for these boats as well.
    1989 Sport Nautique
    • swatguy
      • 1631
      • Midwest/ Northern IL
      • 2008 SANTE 210
      Really depends on what you’re looking to use the boat for. The hulls are completely different and the interior layout storage is apples to oranges ,
      since you mentioned surf I would even take another look at the 226. It’s hard to set up , can’t hide the weight , and the cutouts and angles of the hull near the transom make a wake shaper pretty difficult. The storage in the 220 will allow you to have all the ballast hiddden , the 226 will not. Especially for surf
      the 220 hill has much more of a V hull at the rear. Gives better wakeboard and surf wake.
      the 226 Crossover means it skis fairly well for a bigger v drive. It was a marketing hype “ term “ back in the day for a multi sport capeable boat. Most boats labeled crossovers wet ski boats first outfitted with wakeboard accessories
      • Dan Batt
        • Dec 2022
        • 4
        • Fort Wayne IN
        • 2002 Air Nautique
        I haven ';t looked at 210s as I thought they would not provide much room or a good surf wake, but you both have 210s how is the surf wake and space for people?
        I am coming off a direct drive and want the space, and a good surf wake without external ballast. So I thought the 220 was the best option.
        • shag
          • 2217
          You are going to get a lot of differing opinions and one thing is for sure, most likely going from a direct drive - you should notice better storage in any of the above. The 220 can be finicky for wakeboarding - not sure about surfing. The 226, as stated above, was a 'crossover' , and attempted to please all - but I'm not sure it did that as I believe is was only produced 1-2 years. IMO, you might be hard pressed to find a decent surf wave with no extra ballast. If you can push it, look for a 2008-2009 230.
          • Kenv
            • Jan 2004
            • 1070
            • Texas
            The 226 was made for several years...not just 1-2. Also...remember...the 2010 226 is the "Newer" "smaller" 226. I had the bigger 2005 226 and the smaller streamlined 226. Really liked both boats. I would pick the 226 over the 220 if it were me.....or as Shag said.....a 230 would be better than both the 220 or 226.
            • BT
              • Dec 2008
              • 77
              • Alabama
              • 2012 Super Air 230 1997 Super Sport sold
              The 220 can make a really good surf wake with extra ballast and a wake shaper. My friend and I go back and forth from my 230 to his 220. The 220 wake is a little smaller, but is just as solid as my 230. Fun wave to ride!
