Gauge questions
  • aztaco
    • Sep 2006
    • 33
    • SLC, UT
    Gauge questions
    Does anybody know if my 2002 Super Air has the ability to display the lake temp? Maybe on the depth finder or Perfect Pass? Also is it just me or is this not the best place for the depth sounder? Has anybody moved it, if so where?
  • Schmiddy
    • Jul 2004
    • 15
    • Chestermere Lake - Calgary, Alberta
    You should be able to do it on your PP. Mine displays the lake temp when I press the "Menu" key and the up arrow key at the same time.
    Hope that helps!!
    • patoloco
      • 270
      • Indianapolis, IN
      Yeah, I also never understood moving some of the guages down to your feet on the 2000 and up nautiques. For me, the pod on my 99 is just about perfect....every guage is on the dash, including depth finder and ballast, and radio.
      In one quick glance I know the status of everything on the boat. If the current trend keeps going, maybe next year they will move the speed display to the glove box. :razz:
      • aztaco
        • Sep 2006
        • 33
        • SLC, UT
        Speedo in the glove box would be classic, but you would need a waterproof wired remote for it.
        • aztaco
          • Sep 2006
          • 33
          • SLC, UT
          On a more serious note the ballast gauges are fine as they are usualy totally full or totaly empty. The depth gauge on the other hand is almost impossible to see from the drivers seat and seems to beep all the time. I have only had this boat for a few weeks and have not yet taken the time to figure this thing out. I assume that if I take the time and set the shallow and deep alarm depths it should only beep at me when I am launching or in very shallow water. Has anybody moved this to the dash, and if so what did you move down? The logical choice may be the fuel guage as I would not want to move the oil pressure, amp meter, or temp guage.
          • Laptom
            • Oct 2003
            • 876
            • Eindhoven, Netherlands
            It's not that hard to move the guage. On the back of the guage are 2 wires. One for the power (ground and +) and one for the depth sensor. Unconnect these, screw the guage lose by hand (really easy) and do this the same with the fuel guage and install both again. Perhaps you need to adjust the fuel wires to make it long enough to reach it below. It's a 20-30 minutes job to switch them.
