Hey everyone,
New to the forum, previous Nautique owner with a few questions about 2016 G25s before I pull the trigger. I’ve done my best to search the forums for answer but had a few unanswered questions.
I’ve owned a number of inboards from a 1989 Ski Eliminator to a 1994 Hydrodyne Legacy, to a 1995 Super Sport Nautique, to a 2004 Wakesetter LSV …. But have been boatless for the last 5 years with moving constantly for work. Finally settled down and wanted to get a boat again. Set out out to find something 24’ +/- 1’ that can accommodate a fair amount of people, surf well, and wakeboard alright (I’m the only one who wakeboards still). Looking at everything from A24, Makai, Ri245 / Ri230, ATX Type S 24, used G25, and used Supra SE.
The G25 I am looking at is a 2016 with the XR7 + triple axle trailer with ~350 hours. Service records look good, nothing too wonky during its life, and annual work completed by the selling dealer.
The Engine:
I would never spec the XR7 for my usage and the lock of premium gas on-water, but it seems like this is a pretty standard selected option on the G25. Is this the right engine for this boat? Other than it being a thirsty option, it looks like all indications point to reliability being solid. Seeing as it is out of warranty, and I traditionally have always done most maintenance myself, how is the XR7 for “at home” maintenance on the basic things? Plugs / wires, oil changes, I assume there is still a fresh water pump/impeller for the HX, winterization, etc?
Surfing and Wake performance -
I can’t imagine the stock ballast of 2800 lbs is sufficient for this boat, especially for surfing … so what’s the best option, lead or plug and play? My concern with lead is I have an 8k Floe VSD lift, that is already probably close to its limit with the boat + fuel + gear + 2 people. I’m sure it has a factor of safety, but would rather not test it. In real world use with 1,000 lbs of people weight in the boat, how much additional should I expect to need to run?
Linq Screen:
Is the new screen they added better enough to write of 2016s? I would prefer analog gauges and switches, but since that isn’t really an option, the 2016 screen looks easier to swap if it were ever to die. Any feedback on that is apprecaited
…. Any other notes, callouts, or items of concern folks would have with a 2016 G25?
Thanks for any insight!
Appreciate it!
The Engine:
Linq Screen:
Appreciate it!
