I am looking to get into a 230 and a 2012 popped up right near me. I saw it yesterday and the interior is perfect. The gel coat has a few imperfections (scratches and a spot that looks like somebody buffed too aggressively and went through the flake) in the blue metal flake. I am guessing it may be tough to repair but I am ok with living with that or having it professionally repaired. Also it looks like it will be below the waterline so it shouldn't bother me when using it. Anybody have any tips for removing minor scratches from metal flake? Can I go through compound, polish etc like I have done successfully on regular gel coat?
I am going to water test it today. I am pretty familiar with Nautiques and boats in general so I know to check fluids, shaft and rudder packings, ballast but anything in particular I should be on the lookout for with this year/model?
I don't think it is a Team Edition as it does not have the LINC screen but part of me thinks that is a good thing to have less technology in an 11 year old boat even though it will complicate adding NSS if I decide to do that down the line. However the speed control seems to be Nautique Cruise (see Pic Below) or at least I don't think it is PP or Zero Off. I can't seem to find much info on this system. Is this paddlewheel or RPM based? Will this work ok to hold wakeboard and surf speed with more than factory ballast? Could it be upgraded to GPS or would I have to swap to PP or Zero Off? If I would have to switch can any of the components be reused or is it the whole system I would need?
